Im anti woke too, usually about 8am when the alarm goes off
Yet here here you are, posting about my personal style.I‘m always intrigued by some who feel the need to personalise things. I’m very much anti Woke and believe we are all entitled to an opinion, regardless of how that may upset others, but it can always be made without it becoming personal. In my opinion thats the mark of gentlemanly behaviour.
Yes,, and whist you were making furniture, and some useful videos along the way, we could all see your integrity but always slightly mindful you might have been hyping products. For me, and I only speak for me, knowing you have an income from the videos now - Google advertisng fees for a start - makes the videos you produce more suspect. Sorry, but that is the way it is; you've demoted yourself to become an 'influencer' with about as much credibility as Piers Morgan's left foot.
Aminster say "The Tenso is part of the Lamello Zeta connector range; it anchors in the T-slot in the 'P' system groove. This invisible fitting clamps two parts together with a tensile force of 15kg. The retention force of 25kg makes a tight connection that does away with the need for clamps. Use the Tenso with glue or with normal biscuits or other 'P' style connectors." ... so 15kg clamping force rather than 7kg petermiilard suggests. Also try using the peanut on long mitres!
Ive just realized youre the chap in the vidsWell, leaving aside the silliness of that paragraph (I was earning money from Adsense while I was still making a living from fitted furniture, and I have no idea how much credibility Piers Morgan's left foot has - do tell) that's absolutely your right to hold those opinions, no matter how wrong or baseless they are.
I'd have to dig out the paperwork to be sure, but I was taking my 7Kg figure from the original docs that came with my Lamello - the folks who make the machine, not the ones trying to sell you one. Or - wild idea - try watching the part of the above video where the Tenso-fitted carcass collapses under its own weight as I turn it from its end onto its base - around 09:45 - and then tell me with a straight face that that's '25Kg of retention force' per fitting, in action; that's 30 Tenso connectors in that carcass, btw, all letting go with alarming ease.
As for Peanuts, use them, or don't - I really don't care one way or another - but as I've said repeatedly, they're an interesting connector, and an alternative that's worthy of consideration, whatever jointing system you already have in place. I'm a long term Domino user and I can't imagine being without one as it is, in my experience, the most flexible and versatile jointing system by far - but that didn't stop my buying a Lamello Zeta. And owning both didn't stop my trying the Peanut system - which incidentally, was designed for exactly that kind of awkward joint (long mitres/bevels) in the lowest-end materials imaginable.
Enjoy the rest of the weekend. P
I think it is one of these modern bull shiete words that some muppet has invented to define something they did not understand, probably that weird brigade who cannot accept that humans are male, female or right angle and want to try and classify everything else in an attempt to make it acceptable.I too am anti "woke".
Mainly 'cos I've not a clue what it means!
HI Derek,This topic comes up occasionally on various fori, and the common response is for someone to slag off biscuits after they have purchased a Domino. Generally the point is missed, in my opinion.
By choice, I built solid wood furniture using traditional joinery with hand tools. That is my go-to for quality furniture. I would not use a domino for large mortice and tenon joints - the advantage of proper M&T joinery is that one can design the joint to fit the purpose. Dominos are one shape (in different sizes) fits all.
Still, I use machines because they are the appropriate tools for preparing boards, and I have all the power tools most could wish for. That includes a Festool Domino DF500 and a DeWalt biscuit machine. Both are useful and both have strengths and weaknesses. Keep in mind that dominos are short and deep (like mortice and tenon joints) and biscuits are long and shallow (like a spline).
When I built my kitchen I used the Domino for the great many frame-and-panel doors. These needed mortice-and-tenon joints. I am presently building a couple of bedside tables, which have mitred edges. These use biscuits. The case is 19mm thick and I could not use dominos to reinforce the mitres (as the mortice would go straight through the board).
I do believe that the bad rep biscuits got was due to their being used inappropriately. They are never going to be a replacement for a loose tenon since they are too shallow. Similarly, dominos cannot replace biscuits with shallow joinery since their strength lies in their depth.
Get both machines. I am waiting for the great revival of biscuit machines, which will occur when many realised they they were hasty in getting rid of theirs!
Regards from Perth
Derek
Your furniture your choice of alignment, but are you sure that the 4mm domino is too big?The case is 19mm thick and I could not use dominos to reinforce the mitres (as the mortice would go straight through the board).
I would treat his views with the respect they deserve, (zero) as warped and twisted as they are.Enjoy the rest of the weekend. P
I haven’t tried domino mitres but I’m pretty sure it would be OK
I am making bedsides all the time ( a product i sell on etsy) simple hardwood cabinet with miter constuction also with 19mm thick material. You can definitely use dominos on 19mm material miters. The trick is to remove the preset thickness stop so the fence drops down completely then lock it off. This way you are plunging the domino right at the top/thickest portion of the mitre and preventing the cutter from blowing out the otherside.
What a typical Brit bit of nastiness.Peanuts are limited function connectors: butt joints only, pretty much. Cheap and cheerful. I used to do very similar with #10 wood screws at a slight tilt, so the countersink head would climb the pocket when driven sideways to edge join boards. That was over half a century ago and it's now been resurrected and over-hyped as peanut.
Nuts is about right. And YouTube 'what's his face' is just making a living promoting it. He's given up the day job, remember. His video showing the peanut faster than a Zeta 2 constructing a cabinet, rather neatly neglected to fully account for the time spent making peanut's jigs. A little less than honest IMHO.
4mm wide !!! What are you smoking???4mm wide dominos .... you need a million of them. Compared with a full size biscuit, which is considerably wider. Plus the biscuits have a little more lateral fiddle room to line up edges.
Here are some pics of biscuiting a mitred case (actually two). This represents my quick-and-dirty make-your-wife-happy furniture.
The biscuit joiner needs a spacer (6mm MDF) on the fence to lower the cutter ...
PM has provided plenty of information FREE to viewers and always goes the extra mile to identify and review ‘cheaper alternatives’ to the higher price solutions.
He has been a great help to me and to thousands of others.
So what’s your USP? How many have you helped?. How many people have you entertained with you superb social skills- both your friends I suppose?
I hope you dont mind me posting them up, but your jigs are just fantastic, and save me a power of brain fogging throwing hands in the air kicking stuff across the workshop tantrums.
Thats a great workshop set up you have. Very planned out.
My own is a mere 120square foot, but poorly arranged to be honest. This is the problem from coming from years at a private cabinet shop which was about 1000 sqm, had everything, different rooms for finishing, machines et all. I thought all private shop were about that so it was a blessing to see yours wasnt like that but very thought out and fitted.
Keep up the good work![]()
Not sure this thread was ever about woodwork, but yes, let's give it a shot. So @TRITON, have you bought that Domino yet?Enough already, enjoy your day folks, let's get back to woodwork?
No. Going to be a decent extractor first.have you bought that Domino yet?
