JobandKnock
Amateur curmudgeon
So, "thread topics, are they really a gimmick?"
The first point is that placing multiple dominos using the tight setting in precise locations is neither rocket science nor is it difficult. It’s how I started using mine. If you can’t be bothered to take the time to be exact or understand the technic for placing them then using the first wide setting on one side in some points just makes a fast job faster.It is very easy to place two rows of 10mm dowels with precision using a dowelmax jig, it is not so easy to place multiple dominos without using the sloppy setting so it is not suprising that the dowel joints come out stronger. If you could place the Domino's as easy then they would be stronger, as yet I have got some ideas using the FCC tools alignment jig and spacers on the plate but not 100% yet. The placing using the dowelmax is just easy but slow.
I think that’s off topic and shouldn’t be askedSo, "thread topics, are they really a gimmick?"
I will say that I have tried probably almost everything to achieve what I want, the biggest step forward for 18/22 mm sheet goods is the FCC DAJ, that delivers a precise means of location every time. Putting a single domino into a joint has been acceptable in most cases but when I need two it becomes more difficult, many people will say that the sloppy setting on the 700 is too sloppy, it could be reduced. On the other point gaps in joints cannot be good, if there is a gap then you are reliant on the glue more, with wood to wood contact the loads are directly transfered.The first point is that placing multiple dominos using the tight setting in precise locations is neither rocket science nor is it difficult. It’s how I started using mine. If you can’t be bothered to take the time to be exact or understand the technic for placing them then using the first wide setting on one side in some points just makes a fast job faster.
That phrasing suggests that your opinion is that a glue in a wood joint is less strong than the wood.On the other point gaps in joints cannot be good, if there is a gap then you are reliant on the glue more, with wood to wood contact the loads are directly transfered.
Yes that is true but wood to wood, these glues cannot bridge gaps and is I think why I read someone suggesting cassymite glue.However all testing proves that for a long grain connection virtually every modern glue is stronger than the wood.
The space at the ends of a domino slot when set on wide add or reduce the strength of the joint by very little it’s such a small percentage of the glue area, filling it with a gap filling glue, even epoxy or a urea formaldehyde glue will add little extra strength.Yes that is true but wood to wood, these glues cannot bridge gaps and is I think why I read someone suggesting cassymite glue.
The need for a dowel to fill the hole has probably skewed your thinking into believing that it’s the only correct way for a joint
