RobinBHM
Are you mad?I really don’t understand this whole buying expensive tools for the fun of it
OK but if it's an issue they don't take up much floor space - much like a pillar drill. Not very mobile though.Jacob, a morticer is currently £950-£1,800 at Axminster (second hand machines aside), and takes up a large amount of bench or floor space. The domino wins on cost and upkeep, space etc. However, ‘proper joinery’ is best if that is what is needed for the job.
Yes but you have the advantage of a commercial workshop with skilled people so making mortice and tennons is probably something you can do in your sleep and I doubt I could make one as good as one of your worst on one of your off days. I am one of those trying to offset a skills shortage by finding and buying a suitable tool, the 700 Domino with the FC tools alignment jig delivers what my Dowelmax can but faster most of the time and glueup is much easier.I have one, I like it, use it a lot but I don't consider it a game changer.
Yes and we all know that there are no pockets in a shroud! If you don't spend and enjoy it then what was the point in working for it.I am a hobby/general DIY chap and bought the DF500 and have one regret (or is it a yet to be unfulfilled ambition) and that is I have not purchased the big daddy of the ‘Dominos’. Now that is a lot of coin- but my tool accumulating OCD is likely to win out in the end - after all it is only money.
Personally I cant see why they couldnt have made one machine,with maybe different sized cutters, or more adjustment, but when they're doing two it appears to be more about coining in as much as possible.
That is a load of dogs dangly bits, nothing more than a marketing ploy. The reason you could damage a 700 using the smaller 500 cutters is by exceeding the depth, something I keep an eye on when using the 6mm cutter in my 700. Why would a 6mm need a much higher speed than an 8mm?Festool have also reported that the adaptors have caused the 700 to fail, because the smaller cutters require a much higher speed,
Correction between 12mm and 28mm, unless using the 4mm cutter which is shorter.10mm dowels, 25mm deep
I have the DF500 and love it, great for furniture work. I will be keeping my biscuit jointers as I prefer them for panel work as they give a longer/shallower joint. If I were doing larger joinery then I would consider getting the DF700.
Peter
Unfortunately I cant spend all in the saving pot i collect for buying such niceties. Theres an ebike to get first, I'm hoping theres enough left over to get something to add to the woody collection. Ebike will be in the region of £4500-£5000. But if theres 700 left over then maybe I could stretch to a domino jointer, but for what it is, seems more a luxury than a necessity.clearly not that spendy a mood then![]()
Your value system is interesting. You are willing to spend quite a lot on an item that’s going to depreciate fast, but not on an item that has very little, to zero, depreciation.Pricing just doesnt add up![]()
The ebike ill use every day, or 5 out of 7, with some trips to the shops and back, while others are a days ride in the hills. The domino is likely a few times maybe 1/2 dozen times in a year.Your value system is interesting. You are willing to spend quite a lot on an item that’s going to depreciate fast, but not on an item that has very little, to zero, depreciation.
No, but they are hardly portable, they don't really work on sheet stock (especially in the middle of a panel) and they do sort of require a shop...There are these things called "morticers" you know. Have they gone out of fashion?
