KITY 613
sllca
2 Feb 2021
south Wales
Hello guys
I have just seen a Kity 613 come up for sale in my area. I only have a small shed and was hoping somebody could tell me the height of the machine without the stand. I am hoping it will fit on my worktop workbench to save space. Obviously I will be securing it down. Just trying to save space.
Thank you all
Steve
You can download the manual from manualslib.
That gives a height of 1.6m which will be including the stand.
Estimating from the pictures, I'd say the saw is about 110cm.
Maybe this will help until someone who still has one can measure it for you.
I did a teardown of one here on the forum years ago but lacked the space to keep it. You can search the forum and find lots of interesting old posts.
Best wishes
The size of your shed is more important as it will dictate what sizes of timber you can cut with your saw eg a 6 x 4 Shed with the saw in the centre gives you a max cut of 2 ft across the 4ft side and 3 ft across the 6 ft side . Allowing for clearance the dimensions will of course be reduced further .i know ghis isn’t answering your question but important to know . The other option is to use it outside of the shed ..
Edit ; please ignore as for some reason I was thinking of a tablesaw ( these senior moments are getting far too regular..😤🫣🤔
Blade length is 2300mm wheels are 315mm diameter. From this the calculated height from the bottom of the bottom wheel to the top of the top wheel is 970mm. Based on the picture of the machine with the door open, there is 100mm above the top wheel (including the tensioning knob) and 100mm below the bottom wheel, so estimate 1170mm without legs.
I do hope the 2ndhand one you buy is in much better nick than the one I've just bought on fleabay. Mine was in a truly sorry state and I'd say well abused. But I'm persevering. I've learned that a vac should've been attached to the saw - evidently the previous owner(s) didn't bother, because every nook and cranny was really jampacked with sawdust. It came minus a few bits, including the fence, so I guess I need one of those. The bearing(?) which is at the bottom of the red guard is very badly scored/worn out, so I probably need to buy that assembly too. Or can I buy just the scored bearing? I bought it as a project, but ...
I have one of these, good machines. I've just been out to measure it. 44 inches to the top of the blade tensioning knob. So, very close to the previous estimates!
