The first job today was to see just how salvageable my floor is. I'm relieved to report that It does look as if all is going to be OK. That dark patch you can see is just grout dust swept up from the four boards you see in the picture. So a good scrub with a towel will sort it out, I am sure.
I was going to fit the skirting next, but I plan to have a small kitchen unit in the back corner, so it seemed sensible to fit that first. I'm a bit reluctant to admit that I went to B&Q. I asked the NYL what the thickness of the back panel was. 8mm, apparently. I thought that would be pretty robust so I bought a 1000mm and a 500mm unit and came home.
Well what can I say? It is adequate. No more. There are chips in the melamine and the first cam I put in just broke as I tightened it, and I wasn't being heavy handed. They are made of cheese. But at least nothing was missing. TBH it looks as if it an ex-display model, even though it was in a sealed box. And oh yes, the back panel is 3mm hardboard, not 8mm.
Included was a Customer Care card, so I rang the number. It goes to Norwood, who make for B&Q. The phone was answered almost immediately by a NYM who expressed his condolences. Apparently it is only the Cooke and whatever-it-is range that has 8mm backs. Anyway, he is sending me a spare cam and a replacement drawer support piece, which was the most badly damaged piece.
It'll do, and is was inexpensive, I suppose I shouldn't be surprised.
Now then, I could do with your advice.
There is some discussion above about the clearances at the edges of the floor. When we laid it, we kept 11mm at the edges
but already, the gap is smaller along the back wall. Here it is about 8mm
So it has already expanded a bit. I'm wondering if I should trim it back. I've been given a door trimmer thing, a cross between a router and a circular saw. I've not used it, and neither had the guy who gave it to me, but I think it would do the job quite well. Should I go to the trouble?
It will be easier to fit the skirting if the architrave is fixed first, so in order to do that I had to line the door first. I have lots and lots of spare T&G cladding, so it made sense to use that. There isn't quite enough width to line the whole doorway with the flat part, so I kept the scooped out bit to the front But this means that I have to scribe at the corners. To do that I mitred then first and then cut to the line created. The tapered face is because I didn't have the saw blade perfectly vertical.
I had to clean out the other side as I'd squirted a load of PU foam into the gap. Messy, isn't it?
And so, as the afternoon drew to a close, I decided I wanted to put up one piece of architrave, just to see what it would look like. I did and it shall look good when it is finished. But when I came to fit the top piece, I found that it is not long enough. It's long enough for a door up to 33" wide, but mine is 36", and so it is too short. Never mind, I thought, I have a bit of architrave left over from doing the roof. It's wood rather than MDF, but no matter. Until I put them both together and found that although they are both torus, they are not from the same cutter and therefore will not mitre properly. It's too late to take the first piece off as it is glued as well as pinned, but I think I can salvage it. I'll tell you how if it works!
