Wooden Panel for my car jack.
I bet a board of phenolic type plastic would do.
I have some old locker doors of it and have also got shower cubicle walls from it too.
If the OP could upgrade the accommodation for his jack board to indoor storage, an offcut of kitchen worktop might do well.
This thought comes from peering into skips from the upper floor of the bus...
If I mis-spell 'peering' above by omitting the 'r', the phrase takes on a very different meaning...
Completely agree - I just don't know where i'd find such a thing being thrown out in sufficient sizes (1mx0.6m ish - i'm away currently but I will measure the boards I have when I get back).
100% - I think the plywood would be fine to be fair if it were stored inside, it's only an issue that has developed with it's age... Indoor storage is sadly only a dream at present. Hopefully one day a garage will negate the requirement for any of this!
There are some plexiglass sheets near me going for free on facebook, look to be about 5mm thick, I think i'm going to give those a go first and they should be simple enough to just screw to the boards I have, i'll chamfer the edges so I don't catch myself on them. If that plan fails (I have suspicions that it might crack under the weight, although they will be fully supported by the plywood underneath them) then I will move towards some aluminium checkerboard (using the flat reverse face) - although it looks like I will have to be a bit more patient/active on my search for those - I'll keep an eye out.
Only issue with a lot of modern cars is they are very close to the ground. I can't use a proper garage jack on the wife's mini on the drive. With the board under it it is too high. I have a couple of baby ones that I normally use for changing a gearbox or similar that are ok. I suspect something as thick as a kitchen worktop might cause even them a problem. Shame, because strength wise would be good.
I know it's not what the OP wants but one of the best things I have bought are two-piece plastic ramps. Long ramp section which can be removed out of the way once the car is up. And they grip really well so don't just slide along in front of the car when you try and drive on as the metal ones often do.
Brilliant.
    1 MB
Bolting the angle to the board is not a great idea.
Doing so means you have to move the entire board around to position the jack.
It is likely you would want the jack at a different positon relative to the centreline of the board when working on the left or right or side of the vehicle.
True, but you have to move the board around to reposition the jack anyway.
Unless it's an 8x4 board 🤣
How about changing to a bottle jack, which doesn't need to move?
The car is quite low so I have to use a low-profile trolley jack to get under it. Someone gave me a bottle jack years ago when they were clearing a garage but it was useless to me as I couldn't get it under any of the cars I had. I can get it under the car using my boards but there isn't much free space similar to the experience @Fergie 307 reports.
I have never owned ramps but I am sure they make life extremely easy for oil changes and things like that - however because I have older cars (225k miles upwards) I end up doing more than my fair share of varied work with the wheels off. The situation that has prompted me to post this is that i've got to change one of my wheel bearings this week - so the ramps wouldn't be any help for that! Plus, I am very space limited (hence my boards have to live outside), and ramps are bulky so I would struggle to store them.
I feel for you, spent many years doing the same. Have finally got my kids away from home and reclaimed my workshop so have a powered lift exhumed from under all their junk. Sods law dictates that one of them will have an issue when I already have something on the lift that can't be moved, so out comes the board and jack. Never was exactly fun but as you get older laying on your back in the rain struggling with a rusty bolt definitely loses any charm it might once have had :)
Sam 93, I have a suggestion! I have several steel filing cabinets, re-purposed as tool cabinets in my barn. These cabinets have sheet steel shelves with rolled edges, to stiffen the shelves. It would be easy to cut your ply to fit inside. There would be no edges to catch on. As you are in East Sussex and I am in West Sussex, if you were ever my way I would give you one. Without measuring I would say they are around 36" X 15" and the edges around1"deep. They are painted and could be stored with a plastic bag over them. I am sure they turn up in Tips or metal scrap yards.
Beware the jack sliding on any slippery surface like a worktop or sheet metal. Or the board on the driveway surface. Especially so if your driveway is sloped.
I have the same problem on my tarmac driveway. I tend to use an old bit of ply too, but as you say the jack's wheels need to move rather than sink into the ply. I wouldn't trust the jack alone either, and also use some axle stands
Scissor jack ? The ones I have ( I have trolley jacks and bottle jacks etc too ) go down really flat to be slid in.
Yes always with axle stands. Bought some metal ramps last year..looked at the plastic ones ( on line ) wasn't sure about them as to if they really would not collapse.
So - I had a look on facebook marketplace and happened upon some plexiglass screens which were originally used as 'covid barriers' which a local business was giving away for free. I thought ok they will be perfect - went to collect 2, turned out they had about 30, so of course I ended up with 30 almost impeccable 5mm thick clear perspex sheets. Once I got them home I thought to myself that I couldnt possibly use them for this purpose as they are pristine and would 'come in handy' (oh no) for shed windows and the like. I also have 60 sturdy metal brackets for them which are less likely to 'come in handy' so I will have to work out what to do with them...
So, ashamed to actually use the things I had just got, I went to the port and had a rumage around. I came back with one big sheet of dibond (Sandwich of aluminium, polyethelyne, aluminium, often used for signs), and some offcuts of galvanised 2mm steel.
I cut the dibond to shape with the tracksaw and rounded all the edges with a sander, then countersunk and screwed it to the board. I will give it a go with the jack today, but I am 50:50 as to whether it will have sufficient surface strength or whether it will crack/indent. If that fails, I will clad it with the galvanised steel, although I only have a grinder to cut the steel with so it will be somewhat of a challenge to cut that straight...
Thankyou for your offer that is very kind of you! It prompted me to go and have a search for something similar in the scrap areas near me.
Hmm, yes this is a concern. My driveway is slightly sloped - I wonder if I will need to scratch up the dibond surface (currently very smooth) to make it secure. Alternatively I could probably find some kind of material to stick on to the face. Yes I always use axle stands.
I have a low profile trolley jack which is ideal becuse it fits under easily and gives a good raising height to 45cm or so which is really handy if doing a clutch or similar.
Update - The dibond was ok, Jack rolled freely, didn't crack, nothing slipped or felt like it was going to. I think I would be more concerned if it were wet outside because perhaps the wet surface might be a bit worse. After I finished I had a look and the front wheels made some slight (<0.5mm) indents into the surface, I wonder if it will have a limited lifespan...
I don't have enough dibond to do the second board in it, so that one will be done in galvanised 2mm steel. I've only got offcuts so I will have to cut that into strips with an angle grinder and then lay them on next to each other. It might be a bit of a bodge but we will see. I am confident the 2mm galv steel will do the job well, I am just not confident on my ability to cut it all nicely to shape. The dibond was easy because I could cut it with the tracksaw.
Write your reply...
