RobinBHM
Why not just go for planning permission, you've always got your hands tied if you try to work with PD restrictions, and have to engineer a solution that may cost more in the long run, and will always be a compromise, I wouldn't build anything on this scale without it, and certainly not without a SE design input.
A couple of hundred extra mms would make all the difference.
2.5m isn’t much, because that’s from ground level.
