Inspector
Nyuck, Nyuck, Nyuck!
I was wondering why build two structures side by side? To my little mind it would make more sense to make one larger building, divided down the middle so the need for a ridge beam is eliminated entirely because all the rafters can sit on top of the middle wall. Construction is simplified. Less materials needed since you are not duplicating walls. You don't have the issues of putting siding up between them assuming they are close together. Your porch would be wider if desired.So that would be eves hight max 2.5m and ridge max 4m right? so 2.5m away from a border. My garden is only 11m wide and im planning on putting another building side by side so mine is only 40cm away from a boarder. However i love this roof type and dont want to go down the flat roof option![]()
