Well here is the frame and roof (EPDM rubber) completed in October. I don't have anywhere else to store the timber and other bits and pieces whilst I do the project, so it's stored inside the shed and as you can see, it looks (and is) a state.
Anyway, it was time to get on with the cladding. We decided we really liked vertical cladding and we settled on board-on-board. I liked this because it meant I would only need 1 lot of battening which would make the overhang smaller.
Thanks to a tip I picked up from Ali Dymock's channel, I spaced off the battening with 6mm ply so I do have a small gap with the cladding as well as all the holes board-on-board creates.
And here it is with the first layer of cladding in late November and door frame in. This wasn't too bad to put up - just a long and tiring process. The cladding is Siberian Larch from Silva Timber and will be oiled. Note that I didn't (and still haven't) done the cuts for the cladding around the door / window.
This was the state of the inside of the shed! As you can imagine, I have bumped on a fair few things trying to move around in there
You can't see it from this photo but there's a ton of cladding, battens, soffit boards and other bits and pieces in there!
