Have you got a plan of your workshop, either a floorplan or external view?
I've got to say I think youre spending alot of money on that shed considering the size!
I built mine at the back end of last year and I reckon I got change from about 5k. its 4.4m x 2.9m
3x2 studwork frame on a 4'' reinforced concrete base sitting on 3 rows of engineering bricks.
GRP roof.
Siberian Larch cladding on 2 sides with Metal box section sheets on the other.
Insulated internally with 18mm ply lined walls.
No power into it yet but its right next to a Garage with a 10mm2 SWA cable feed to its own Consumer unit so I'll just run in another circuit to it once the weather perks up a bit.
Haha Nope. One of the joys of using Apple products! The pictures just dont end up the right way up when you upload them to forums. Really annoying!Are you in Australia mate ?
Thankstop notch she's btw
Im not sure its in part A, but every roof design I had calcs done the SE always used 0.75/sqm for snow load -thats a 1 metre depth of snow, which I guess somebody has calculated is 75kg.are you taking that 0.75 value from Part A?
140mm wide boards on first with 70mm wide boards on top. 20mm thick.I like the cladding is it a big standards planks over lapped ?
This shows it a bit better. All coated on all sides before installation with Osmo Poly X Larch colour which greys it ever so slightly
