The shed I mentioned before that I made the alarm up for is my stepfathers (with some VERY nice kit inside) less than two weeks after having it built and moving everything inside, it was (successfully) broken into- by them putting a pipe wrench on the factory doorknob and simply twisting it off!!!
I went digging through my old photos and found the pics he took of his 'upgrades' after I fitted the alarm...
Being the inventive (and rather nitpicking) guy he is, this was his 'security upgrade' to the shed door...
That's shown in the 'open the door' mode- the 5mm thick metal plate slides to the left and is locked by a high security padlock in the closed position- once you get it to that 'open' position, you insert the key in the keyhole to the right, and put 'the handle' into the round hole to unlock the door...
This is what that handle does inside the door...
Yeah- seriously- thats a bloody SHED door...
All hand built, including the locking mechanism for the door- the only thing 'bought' was the key lock itself!!! (plus the entire shed is lined inside with 3mm thick steel plate!!!)
Even trying to take the hinge pins out won't work- as those 'tongues' on the right of the door lock into 'lock holes' on the inside of the door frame when closed... and the sliding tongues on the left do the same on the other side when moved by the handles...
There's an alarm on there as well (but not one on the house- guess he knows his priorities lol)
It would take you an hour to get into it with an anglegrinder...
What can I say- he is a perfectionist in everything he makes...
(After 20 years, they haven't gotten into it once since his 'upgrades' lol)
