Pocket hole jig - is this one worth it?
Jillos
21 Feb 2025
WR11 8TL
I want to have a go with pocket holes - I make a lot of planters and other bits for my garden, and figure it would just be a useful tool to have. As I've not had one before, I don't want to splash on a Kreg, but I found a you tuber who endorsed this one:
https://amzn.eu/d/9xpvmAQ
As always with Amazon, the reviews are mixed, and a few folk seem to be saying that the drill guides wear out quickly.
Does anyone have one, and is it worth a punt do you think?
I have a Trend one that's very similar - works fine - all pretty simple. Buy one. [You'll probably find the same thing on Banggood/Alie/Temu for a lot less money if that's an issue]
The Kreg range is great but overkill/expensive - watch Shara at Woodshop Diaries on YT - she's the "pocket hole queen" making everything with them.
You might be lucky and find hardened collars that drop in, they're only held in by grub screws. The inserts on that one do look a bit shiney-chromey for hardened ones.
Probably a good deal in respect of its basically a UJK copy, but a 1/4 of the price
So if it is something that is getting used occasionally, then it will more than likely be fine
This sounds like more heavy stuff so you might want heavier fixings, for such jobs I use the Kreg HD jig which is just £50 and the screws are coated for outdoor use.
https://bivenmachinerysales.co.uk/product/kreg-jig-hd-pocket-hole-system/
https://bivenmachinerysales.co.uk/p...ointing-systems-pocket-hole-jigs/kreg-screws/
That Amazon jig for £26 is just like placing a bet on the grand national, you would be better off with this Jig for £20
https://woodworkersworkshop.co.uk/milescraft-pocketjig100/
to get a feel for pocket holes and then maybe progress one way or the other.
I bought a cheap one from Aliexpress some years ago and it’s fine - apart from the drill bit which was slightly the wrong size (too small). I then bought the cheap Trend one for the included drill bit and found myself using it more often than the Aliexpress one.
It was under £20 when I bought it.
