Simple Burglar Alarm for Workshop
You could probably repurpose a car courtesy light switch to work on the door with a relay and big horn for something really simple, although unless you incorporate a latched relay then just shutting the door again would turn it off. And if you do use a latched relay then once activated someone would need to reset it.
Another option is just to get a flashing led, you can get 12v ones or self contained units that work off an AA battery or similar. Some "Alarmed" stickers and that may be enough to persuade them to look elsewhere.
Dampdog2013 is an e bay seller who does kits. Both my alarms are based on his box. Alarm input is a 12v DC feed, so can be adapted to work with PIR, switches etc. the siren he does is pretty loud, although I have used his output to fire up a much bigger one through a relay.
Don't forget hinge bolts, inexpensive, supplement your locks.
Internal Sonic 'bombs' on a key/hidden switch delay (like some narrowboat owners have)
Sorry, just seen above.
Great recommendation - I'm going to order the light/siren from him.
Got some great ideas on here and I'm going to put something together with a 12v key switch.
You can also modify PIR units by gluing a piece of tube on the dome. Reduces their sensitivity and range so they can be used like a proximity sensor. You can experiment with different sizes and lengths of tube. About 10mm ID and 20mm long range reduced to about 6-8 feet and maybe 10°.
Position somewhere that someone needs to walk past to get to whatever you are protecting. Reduced range means much less likely to have false alarms. Handy in situations where a beam isn't practicable.
    386.2 KB
When I first joined this forum a few years ago I posted about a motorcycle alarm bought cheaply from ebay and which is still working perfectly to this day, the make was from memory, Winoma and it is a sophiticated vibration/ movment sensor, it came with a siren and remote control, touching the shed door sets of the siren which runs through a series of whoops and police siren sounds before resetting itself if left alone. Its designed for fitting to a motorbike but I run mine from a bell transformer. In truth the siten is uncomfortable but not extreamly loud, but in the middle of the night, when your trying to creep about burgaling I would think it would make you scarper. The great thing is it does its job before they have smashed there way in.
