AJB Temple
Finely figured
Manufacturers try to maximise profits shock.
Thanks, good points well made.Chipmonk you said "They claimed and fought dozens of patents to ensure the barrier for entry was high and blocked the US market, making it more difficult and less financially sensible for other companies to bring products to market."
Given all the manufacturers rejected licensing the system flat out when it was offered to them, they went making the machines themselves. Not an inexpensive undertaking. Blocking others by enforcing their patents is not wrong and the whole point of the patent system. Big Pharma make SawStop look like amatures.
Now as for the added cost of a SawStop compared to any other table saw in the same class. People keep forgetting in addition to the brake cartridge and associated electrics and electronics the mechanical parts are much more robust and complicated (more parts and of greater precision) than a regular saw which add to the cost. I know because I have had mine since shortly after they were first offered in Canada and I can see and compare it to my earlier saw. It must be kept in mind that just because they look similar to other saws on the outside, it doesn't mean the should cost the same.
You are entitled to your rant but I think getting mad over advertising doesn't add up given the number of companies that have lied about their products that were known to be very harmful to us. The tobacco industry for example.
In time the cost will come down. Until they do lets toss all our push sticks into a big pile at Jacob's place and play a game of pickup sticks.
Sorry, I'm not trying to be a hater, but they used the phrase "Your safety is our top priority". That's a flat-out shameless lie.
I brought a SawStop 10" professional cabinet saw from the states many years ago. It is the workhorse of my shop, I use it frequently. I couldn't be happier with it. Extremely precise, solid and safe. My only caution is to use wooden or plastic mitre saw fences rather than aluminum if at all possible. If you accidently touch an aluminum fence to a spinning blade (silly mistake but it can happen when arbor is tilted, for example), the Saw Stop mechanism will actuate thereby costing you a blade and a SawStop mechanism. Nevertheless it is a great saw with a great rip fence. Crazy to see how long it has taken to get these in Europe.The saws are the equal or better than all comparable saws in their category. Manual in very comprehensive and well illustrated. My observations and opinion.
After putting on any fence rails and tables on the bigger saws or removing the packaging on the smaller saws, yes they work straight out of the box. No adjustments needed for the safety mechanisms.
No tinkering, no set up any more than any other new saw.
They are well made and the fit and finish are as good or better than any of the competing saws.
Dust extraction below the table on the ICS (Industrial Cabinet Saw) has a shrouded blade cover that hooks directly to a 4"/100mm port. Above table blade cover port is small like most saws in this arena, better hooked to a shop vac with a HVLP collector below. Like most saws inadequate and needs improvement. My opinion.
Blade change on the ICS is not very different to any cabinet saw.
*Switch off the saw.
*Pull the plug if not hardwired.
*Turn the lockout switch on the saw to off. Padlock it if you like.
*Remove the throat plate.
*Flick the magnetically held door on the side of the dust shroud open for access to the blade nut.
*Flick the riving knife/splitter leaver a quarter turn to open the clamp and remove the riving knife or slitter and guard. Not absolutely necessary but makes for a little more access.
*Use the two provided wrenches to remove the nut and washer.
*Slide off the blade and install the next.
Replace the washer and nut and tighten.
*Check the blade to brake gap, approx 2mm, and adjust the brake with an Allen wrench if required.
*Slip the riving knife/splitter over the dowel pins and flick the leaver to clamp on.
*Close the magnetic dust shroud door.
*Reinstall the throat plate.
*Plug it in.
*Turn the lockout switch on.
*Turn the saw switch on and after it goes through the self check and you have a green light you turn the saw on / off with the paddle.
Cheaper and safer to get into the push stick habit.I brought a SawStop 10" professional cabinet saw from the states many years ago. It is the workhorse of my shop, I use it frequently. I couldn't be happier with it. Extremely precise, solid and safe. My only caution is to use wooden or plastic mitre saw fences rather than aluminum if at all possible. If you accidently touch an aluminum fence to a spinning blade (silly mistake but it can happen when arbor is tilted, for example), the Saw Stop mechanism will actuate thereby costing you a blade and a SawStop mechanism. Nevertheless it is a great saw with a great rip fence. Crazy to see how long it has taken to get these in Europe.
Bin dare done dat Chris. Same happens to one with a regular table saw but instead of a nick in the mitre gauge you take a big enough chunk out that it is no good anymore and you have a damaged blade too. It's a blade and brake replacement cost verses a blade and mitre gauge replacement cost thing. Good aftermarket mitre gauges alone cost a lot more.I brought a SawStop 10" professional cabinet saw from the states many years ago. It is the workhorse of my shop, I use it frequently. I couldn't be happier with it. Extremely precise, solid and safe. My only caution is to use wooden or plastic mitre saw fences rather than aluminum if at all possible. If you accidently touch an aluminum fence to a spinning blade (silly mistake but it can happen when arbor is tilted, for example), the Saw Stop mechanism will actuate thereby costing you a blade and a SawStop mechanism. Nevertheless it is a great saw with a great rip fence. Crazy to see how long it has taken to get these in Europe.
Not quite sure what you mean, but if you are pushing a piece through with a mitre fence, past the blade, but feel hands too close, then the push stick answer is to set the piece before the mitre fence (turned around) and push the workpiece up to the fence with a push stick (or two) and push them past the blade together.Bin dare done dat Chris. Same happens to one with a regular table saw but instead of a nick in the mitre gauge you take a big enough chunk out that it is no good anymore and you have a damaged blade too. It's a blade and brake replacement cost verses a blade and mitre gauge replacement cost thing. Good aftermarket mitre gauges alone cost a lot more.
In cases like this when you overlook or don't realize the change in an angle adjustment (mitre gauge or blade tilt) will put the tool in the way of the blade all the push sticks in the world won't make a difference Jacob. Or do you use your push sticks to push your mitre gauge or wave them back and forth to magically reset the clearances?
and or clamp it to the fence, etc.Not quite sure what you mean, but if you are pushing a piece through with a mitre fence, past the blade, but feel hands too close, then the push stick answer is to set the piece before the mitre fence (turned around) and push the workpiece up to the fence with a push stick (or two) and push them past the blade together.
You never seem to get it Jacob. What Chris and I were talking about was when you have your miter gauge set close to the blade for support while cutting at an angle and return it to cut 90º again you may not notice that puts the mitre gauge in a position (in front) to hit the blade. It can also happen if you tilt the blade and don't move the mitre fence away from the blade. In both cases when the blade contacts the mitre gauge even when your hand is at the other end of the mitre gauge the brake will fire the same as though it was a flesh contact. Push sticks would be completely useless in these instances because it has nothing to do with where your hand is. It is a method or procedural mistake in that the operator has missed or forgotten to check clearances of where the tool will cut.
We do use push sticks for all the same cuts you do but they are not an automatic answer for everything like you always have to spout off. When cutting, when moving the saw across the room, when changing the blade, when scratching your back, your answer is alway push sticks even when completely out of context.
Here is a picture of the mitre gauge fence when it was used close to the blade for a 45º mitre and return back to 90º without resetting the fence back from the blade. The nick is the mark left when the blade brake stopped and dropped the blade below the table. I'll add them
Here is a picture of a cut made by a regular table saw that a buddy did. His widow sold me the mitre gauge after his unrelated death.
I can't load pictures either. I'll add them to the thread if it ever gets working again.
I don't disagree with that Ed but I do disagree with being told push sticks are the only answer to everything.With respect;
Everything you just listed can be boiled down to nothing more than poor work habits.
Not checking you clearances, or miter gauge position of forgetting something, etc.
A SS isn't going to make you a more thorough or less forgetful woodworker.
This is like saying, I got a shock because I forgot you shouldn't put you finger in the electrical outlet. A grounded outlet isn't going too save you.
No I don't get it from your incoherent rambling description! Looking forward to seeing a diagram.I don't disagree with that Ed but I do disagree with being told push sticks are the only answer to everything.
PS still can't edit posts!Just wondered about how effective the SS is. I've seen impressive vids whereby touching it with a sausage stops the blade dead. But what happens if you sweep a bunch of sausages fast into it, like sweeping your hand as if clearing off shavings, but hitting the blade by mistake.
Would it just take off two fingers instead of four?
How quickly does it stop?
n.b. do not try this at home!
They aren't the only answer but they are just as safe and cost less than a SS.I don't disagree with that Ed but I do disagree with being told push sticks are the only answer to everything.
