Alexam
Bandsaw Boxmaker
That's an interesting one and I would be interested on the answer. I have the same machine and the blades have plenty of clearance.
Alex
Alex
Indeed. My BS300 claims 3/4", but, errr... don't do that (bitter experience). 5/8" is a sensible limit.woodpig":2u1epnq0 said:It has been suggested that the quoted maximum blade size is often somewhat optimistic, at least to get the best from the machine. On this basis I wouldn't expect to run anything bigger than 3/4" on the BS400. If you regularly need to run a 1" wide blade it may have been better to look at the Startrite range. We had a 401E where I used to work and that worked well with a 1" blade. It may be worth speaking to Ian at Tuffsaws to see what he has to say if Record can't help?
woodpig":1s8694nv said:It has been suggested that the quoted maximum blade size is often somewhat optimistic, at least to get the best from the machine. On this basis I wouldn't expect to run anything bigger than 3/4" on the BS400. If you regularly need to run a 1" wide blade it may have been better to look at the Startrite range. We had a 401E where I used to work and that worked well with a 1" blade. It may be worth speaking to Ian at Tuffsaws to see what he has to say if Record can't help?
Wobbly/wavy cuts are most likely a dull blade or (under) tensioning issue, but there's no reason ceramic guides couldn't be used (I don't know a compatible brand/model though).Jmac80":n4zbo6z0 said:My cuts seem to be pretty wobbly/wavy from the bandsaw lately?
Also does anyone know of any ceramic guides/blocks that can be used instead of the roller bearings?
Thankssploo":l9m1wq5c said:Wobbly/wavy cuts are most likely a dull blade or (under) tensioning issue, but there's no reason ceramic guides couldn't be used (I don't know a compatible brand/model though).Jmac80":l9m1wq5c said:My cuts seem to be pretty wobbly/wavy from the bandsaw lately?
This link may be useful regarding understanding blade behaviour: http://woodgears.ca/bandsaw/resaw.htmlJmac80":122w2ra6 said:Thankssploo":122w2ra6 said:Wobbly/wavy cuts are most likely a dull blade or (under) tensioning issue, but there's no reason ceramic guides couldn't be used (I don't know a compatible brand/model though).Jmac80":122w2ra6 said:My cuts seem to be pretty wobbly/wavy from the bandsaw lately?
It's brand new blade, will up the tension and retry.
Would love to get some ceramic guides!
Jmac80":3gti0wcz said:...It's brand new blade, will up the tension and retry.
Wizard465":1qzowncj said:Hi All
New to the forum so dont mind me, just got my BS400 yesterday but seem to have quite a bit of vibration when running, any advice on this would be great.
Alexam":3mrwk7cr said:Wizard465":3mrwk7cr said:Hi All
My BS400 is the same, as the floor is not always completly level at all corners. I move it around until it is stable, by shaking it until it has no rock at all and then used a marker pen to draw around the base so that I can put the machine in the same position again. I actually have 3 positions outlined. Without wheels you wouldn't be able to move it around, but that may be ok for you. I need to move mine as it's in a garage where we put the cars.
So I gather, but hearsay to me. I used to give the blades a spruce up by turning inside-out and running backwards on the machine with a grinding block.Random Orbital Bob":yrtkm8bb said:.....
Chas...that sharpening YT you linked is the very one that Ian from Tuffsaws recommends.
