Wood insert nuts, any good recommendations?
4 Aug 2024
Newport, south Wales
I bought these: https://amzn.eu/d/6EH2kpH but they're terrible, rounded out the drive hex after 3 inserts. Not that I want to move them but wanted to trial them before drilling my hexaply.
I'm using them for fitting bike fork mounts and for fixing down 8020 type aluminium profile (30x30mm but supporting a bed in a campervan) so need to have some movement resilience.
I've seen The Insert Company online. They do zinc alloy, brass, stainless steel and zinc plated steel. Any ideas for best material or other suppliers?
Thanks very much
Sean
Yes more expensive but when you compare them they have a continous thread form that cuts into the wood which gives a better pull out resistance than those jungle ones.
The devil is in the detail - when you get a pack of 30 or 40 for a few ££ and compare them to a pack of 10 for the same or more cost . I find driving in the cheaper ones is best done by hand rather than the current trend of using an impact driver for everything. If the bikes will likely be wet at times then consider stainless steel inserts and fixing bolts etc .
These can be a pain, I agree that the ones with a continuous thread are better.
But, they are harder to screw in. Last time I used stainless ones and had to go half a mm over on the drill bit to get them just right in birch ply. If you don`t have the right half mm over bits then try wax. Insert by hand with a t handle alen key.
I had to use one of these recently to hold a grub screw in a wooden handle I was making. I did look around and came to the conclusion that as I only needed one, I would make it myself. If I were to buy them then I would definitely go for those with the full thread.
They are available with or without a flange at the top. The flange stops them sinking too deeply into the wood. Past experience shows that the Zinc ones can be a bit gutless and one has to struggle a bit, and experiment to get them to fit nicely with an Allan key. It is often easier to insert a bolt and lock nut, so that one can at least drive them in with a spanner.
The one I made in brass had a coarse 12mm metric thread on the outside. This allowed me to first tap the hole I was inserting it into. I also used some epoxy glue to further secure it. This was much less stressful at achieving a neat fit.
Zinc alloy probably means they're made from aluminium or something comparably soft. Buy the carbon steel ones, they're so much better.
Don’t try to drive them with an Allen key or a flathead screwdriver if they have a slot. Use a correct sized bolt with a locking nut. 2min 30s into this vid.
I keep a combination of both the cheap zinc ones and stainless steel ones. Don't use an impact driver for either. If you don't use them often enough to acquire the skill to power fit them, then do it by hand would be best in my opinion. As suggested, don't try using a flat-ended screwdriver but do as Fitzroy suggests. Some timbers may need you to make a slightly larger hole which has never caused me a problem. If the zinc insert has a collar, don't try to force it in that last 1mm to make it flush fit. Measure the collar and use a Brad point bit to take that top 1mm surface away before drilling your clearance hole. It will be a much nicer fit. Done correctly the cheap ones will be just as strong as the nicer-looking stainless steel type in most cases.
Good point on the different sized holes! I fitted the same size insert nut in pine, ash, and oak and they took 8.5mm, 9mm, and 9.5mm holes for them to insert without breaking and also feel secure.
I love these inserts and thanks for the recommendations of the higher-quality ones.
I just wondered if any of you had tried these with the axis along the "grain" of 18mm plywood (i.e. into the edge). This is for a repair job where the original manufacturer secured an access panel with long screws going in, biting into a short hardwood dowel (like a barrel nut, but glued into the ply). I'd rather have something like this, but metal barrel nuts wouldn't work (because there isn't enough thickness, and there are so many screws to secure the panel that their prone-ness to spinning would make the job nigh on impossible).
All my instincts say "noooooo!" and I'm thinking instead of epoxying studs into the ply, using thumb nuts on the outside, but these will be proud of the panel at the front, which is a drawback, even if I get pretty ones).
I have inserted this type of insert in the edge of plywood, but only in 18mm birch plywood with a generous pre-drill diameter. I wouldn't want to risk this in most currently available plywoods. An alternative, which I haven't proven, might be use the non-flanged type insert, drill a counterbore to clear the o/d of the insert to say, 25mm depth and then drill for the insert. This would require a longer bolt, but might just avoid delamination.
I bought several size variations of those (probably cheap ones but can't remember) and I've definitely learnt, through losing the first few, that I now only insert them by hand and if I repeatedly back them out a little on each turn I now don't lose any at all....I can see the idea of 'wax' working along the same lines 👍
Like anything- you get what you pay for- Amazon is usually just resellers buying in bulk from Alibaba and selling in split lots- usually with a few hundred % markup!!!! (and often manufacturers 'seconds' to boot...)
