Trevanion
Greatest Of All Time
Keith 66":2e3gas95 said:Has a single phase motor with belt unloader to allow sstarting on single phase. Before the unloader you got one start per 13amp fuse & next start it would blow!
The belt unloader sounds interesting but I don't see why you would need it if you put it on the end of an adequate supply like a 16A plug or directly connected to the mains unless you've only got a 13A supply? Mine's a 2.2Kw 1Ph motor but I have seen them run with 1.5Kw 1Ph motor fine too so long as the correct supply is used.
