yea you are right scrit about the space problem, but you can get some metal trays which give you a little hope.
however, the waste bin can be compromised by the lack of space too,
and of course it always get full to quickly,
and now in many places you have to have 3 separate bins for re-cycling
gawd knows where flat dwellers are supposed to put those :lol: :lol:
wouldn't mind but they are all so b big
second the isolaters, those red and blue taps are vital ,but don't forget
putting them on the washing machine pipes as well as those for the
dishwasher. actually a good trick is to put a pair very near where your cold water entry is to that you can isolate the whole area before the work. it also makes it easier to isolate leaks
cause they will occur.
i use plastic waste pipes, and never weld them.
i also suggest using those flexible metal pipes up to the taps, and Always fix the taps and tails to the sink before you fix it down properly.
cut the hole, check it works, fit the gasket, and silicon, then fix the taps and tails on the sink whilst it is upside down, and make sure the taps and any water holes are also properly sealed. put the drain in properly, as well as the overflow, make sure they all work before fixing the sink.
next you will want us to come to the liffey factory, and fix it for you.
:lol: :lol: :lol:
paul :wink:
