It kinda makes sense - a standard kettle has a 1.5Kw element, and a single ring induction 2.1Kw so aside from different losses pan versus a kettle even without boost, induction has gotta be at least on-par, and with boost easily beat it. Plus the fact that convection losses aside with induction all the energy is going into the pan and hence water and by heating it in a shorter timescale the losses will be smaller...
Have only just moved house and have new induction hob to install so can do some realistic tests and demonstrate the speed - my last place had a wide 80-90mm one and it was a 'mare getting used to it on boost - numerous major boil-overs..!
I have friends who have a Neff induction hob and theirs takes forever to boil/heat up soup and the like, dunno if they merely haven't read the instructions properly or are merely mis-guided as to how to best use.
Previous comments in this thread make no sense to me wrt energy efficiency 'slowness' - fact is it's basic physics/thermodynamics - if the appliance is underpowered or throttled by the user then env losses increase the total energy consumed to raise x-°C of whatever you are heating, and it's basic power->in directly proportional to temp rise so only difference is time to do it..., but the faster you do it the less losses you incur..
