engineer one
works for me :lol: :lol: :lol:
paul :wink:
paul :wink:
Scrit":2hsemmrm said:Jason, have you ever tried polishing out scratched with a Fein? Just wondered if it's worth getting the kit.
Scrit
engineer one":ixvogpor said:uh what guys jake, no link![]()
paul :wink:
Scrit":935n8vbd said:I have a goodly sized "cluster" of carcass manufacturers around Manchester so that's not an issue. Generally, though, non-standard sizes just means non-standard widths. If you need, say, 250mm deep upper cabs, a corner unit to take 400mm doors, 235mm wide upper gallery ends, or a 140mm wide spice drawer unit (all recent requirements) then they can't help. When I say non-standard, I really mean it :wink:
Scrit
Scrit":1o53kvcs said:Services at the back of carcasses need a 50mm space - the largest waste you'll normally see is a 40mm so 50mm space gives you room to manouvre. Normal carcass depth is 570mm, front to rear, with a base carcass height of 720mm (uppers are 575/720 as a rule).
Scrit
Jake":vcf9yrip said:....vary any of the dimensions - the guy laughed at me for asking that question. It's all CNC, so they just type in the dimensions and it comes out the other end.
The templating should be down to the granite men. That way if there's a b***s up it's their problem. templating does need to be done after ALL the units are in place, though. Similarly a granite worktop can take four or five big beefy guys to manhandle into place - better their backs than yours...... As I said earlier for granite tops any scribing is normally a case of chiselling away the wall - much easier than modifying the granite.sean_in_limerick":16d1mm4k said:I can definitely say that my wall will not be straight and true - nothing in my house is - when you say overhang the top - wouldn't this have to be scribed to the wall still? I agree that granite is probably too painful (for me) to install. My local granite guys insist on a template of the countertop made from plywood - I don't like this as I think the onus should be on them to do the measuring - then there is the cost - I don't think it's that big a deal, and fortunately - neither does the wife.
Either 15/18mm solid backs (for corner solutions/carousel units/magic corner units, etc) or 8mm MFC - most sheet merchants can supply this in white one side / magnolia reverse as most of the major board manufacturers such as Kronospan, Finsa and Egger make it. Kronospan also do a beech / metallika combo in 8mm. A word of warning - get the merchant to cut it down - it comes on "jumbos" (circa 2.6/2.8 metres x 2.0 metres). 3mm is too this and will pop-out much too easily in my experience.sean_in_limerick":16d1mm4k said:...what type of backs do people typically use for the carcases
sean_in_limerick":16d1mm4k said:What thickness MFC is typically used for carcases? I can get 3/4" in full 8*4 sheets, but for some bizarre reason i can only get the 21", 18" 8ft long MFC in 5/8" - is this thick enough?
What material is typically used for toekicks?
George_N":6fsk3lld said:Scrit":6fsk3lld said:Services at the back of carcasses need a 50mm space ... Normal carcass depth is 570mm, front to rear.
Isn't that going to be too deep? If the carcasses are 570 mm deep with a 50 mm gap at the back for services, even my maths makes that 620 mm. If you add another 20 mm for the door that makes 640 mm. I am intending to make my units 520 mm deep + 50 mm service gap + 20 mm door = 590 mm, which should fit under my 600 mm worktop ok. Unless I'm missing something?
Clarification: Yes, George. The 525/720 were HEIGHTS. Standard DEPTH is 570mm for lowers, 280mm for uppers, although when I make uppers I prefer to go 350mm on uppers as that will accommodate a large dinner plate with an 8mm back and a ledge behind. The 570mm deoth INCLUDES the access gap which is put in by insetting the back 50mm. You need to run the sides back to the wall so you don't have a gap to hide at the end of a run.George_N":1kwbjxmg said:Isn't that going to be too deep? If the carcasses are 570 mm deep with a 50 mm gap at the back for services, even my maths makes that 620 mm. If you add another 20 mm for the door that makes 640 mm. I am intending to make my units 520 mm deep + 50 mm service gap + 20 mm door = 590 mm, which should fit under my 600 mm worktop ok. Unless I'm missing something?
George, when I make my own I tend to use an 8mm MFC back slid into a router cut groove and glued in place - but only for those carcasses where there's nothing to get at behind. In those case you can go deeper, too, but all carcasses need a front and rear stretcher in 18mm MFC - the rear one is vertical at the rear, the front one is normally horizontal (but see also note below). Where there is plumbing behind the carcass I'm currently considering a design which allows the back to be inserted and removed from the front of the unit and for sink units I nowadays have upright stretchers front and rear rather than a horizontal one at the front - that means you aren't cutting into a stretcher and weakening the structure when you do the sink cut-out inthe worktop as well as giving you something tyo hang false drawer fronts on in a drawerline kitchen. I've built a couple of carcasses like that already but I still haven't perfected it - yet! The reason I use dowels is twofold - firstly a glued and dowelled carcass is extremely rigid (and all the better MFC carcasses you can buy are all done this way), and secondly I have the equipment to make them. Pocket hole screws or KD fittings work well, but ultimately aren't as strong, IMHO.George_N":wmf2ofso said:I was hoping to avoid insetting the backs as I don't want to cut housings (dados?) in the sides. If I inset the back and just butt joint it to the sides, I'd be worried about keeping the alignment right but I also don't really want to go down the doweling route for ease of production.
The service gap is indeed only for base units. For upper cabs I'd recommend going to this type of hanger on a long rail. You will need to make up a drilling jig and the backs will need to be notched-out to accommodate the rail, but the rail has the advantage over individual plates of being able to span studs in stud walls and soft patches in old/poor masonry walls. The cab hangers are cam and screw adjusted to level the cabs. I make upper cabs so that the backs slide into a groove from the top and sit in a groove across the bottom. A spot or two of glue holds them and the top is screwed through into the rear of the top panel, which is shorter than the bottom panel. Gioves a rigid, strong and square carcass.sean_in_limerick":wmf2ofso said:I think that the service area is only required for kitchen base units? After all of these discussions on the type of back to use i will probabaly end up using 1/4 inch ply or 8mm mdf for the backs - i really hadn't considered the problems of access to the plumbing under the sink too much - some great advice there.
