Guttering
Croolis
31 Jul 2024
Midlands
Yes, it's more shed stuff.
I've never installed guttering or had to think about it in my life. I've decided my new shed needs it. I want to be as cheapskate as possible. There's an old people's home behind my shed. The nearest building is 30 feet away across grass.
I have a fence (I didn't build this), there's a funny little no man's land about a foot or so wide, then another fence for the old folks' home. Nothing but weeds etc growing in the space between the fences. I'm thinking I could pipe the water from the shed over my fence (the gap is ~half a metre bewteen shed and my fence) and just let it drain into the no man's land. Not even bother with a downpipe, just let it flow out and fall couple metres to the ground in there.
Is this a shockingly bad and mardy thing to do? Will it hurt anything? I mean, I wouldn't dream of putting it straight into anyone's garden of course, but there really is nothing down there. Would it trash the fence? Typical wooden fence panels with the concrete base thing at the bottom.The shed is 10ft by 8ft with an apex roof, so two pipes going over the fence.
If I'm not putting it over the fence, I've got to downpipe it to the ground by my shed and/or water butt it, which I really don't want to do. Pricing this up, I'd be up to 100 quid plus on bloody plastic pipe grr.
Thoughts?
A pragmatic approach would be to do as you suggest and go outside with an umbrella next time it rains to monitor the situation. That would tell you if anything bad is happening and if adding a downpipe would help.
As you say, water falling two metres is going to make a bit of a splash so the effect of that is what you have to assess. As an outside possibility, could you make a pebbled area in the drop zone (bit of landscape fabric under the pebbles), which would attenuate the deluge and stop any rebound?
I shall do that, thank you. I'm seeing cheap second hand guttering and water butts online so I might be able to just do that for a fraction of the cost. Do water butts in the UK fill up in a single downpour with a 10ft x 8ft roof? Presumably one gets rid of the water by just squirting it around the garden. Seems like a ball ache. Never owned one, never thought about one :unsure: .
There is an average UK rainfall chart here:
https://www.metoffice.gov.uk/weathe...-weather/rain/how-much-does-it-rain-in-the-uk
Daily data (not from your area) here:
http://nw3weather.co.uk/wxdataday.php
10' x 8' is about 3 x 2.4 = 7.2 square metres. On the above, the largest daily rainfall was 31mm, so that would be a volume of about 225 litres. That is a little over a standard 45 gallon (205 litre) oil drum.
I wonder if you drilled a small hole in the water butt whether it could then drain down gradually over a period of time. Then it would act as a buffer, stopping peak flows doing any damage but not requiring any input from you. Possibly a wick in a larger hole would stop a small hole getting blocked by debris.
Edit: old guttering can lose a bit of plasticity due to UV exposure, so go easy when fitting it. Warming with a hair dryer or heat gun can help it slip into the clips.
Do ground conditions allow for the construction of a "soakaway" on your property for dispersal of rainwater?
I've looked at that stuff, seems to require large holes to do properly. Soil is typical loamy soil that we have so often in UK. But I've only got a space half a metre wide between back of shed and fence (same at the sides of shed as well in fact). Was sort of thinking that a soakaway that close to the fence wouldn't help it much, but I also know nothing about drainage :) .
Here's an idea.
Dig a hole, fill it with gravel/old bricks etc., as a diy quasi-soakaway (proper ones are very deep) put a couple of blocks on it and mount a water butt. Run gutter into butt or butts - I found some slimline 100 litre ones that you could buy as a pair for little more than just one.
In dry season leave the butt tap(s) closed, you have a useful supply for the garden. In winter/wet season open the tap just a little. Water will dribble out and run away into the ground doing no damage. Normal state of butt is empty. If you get a downpour the water goes into the mostly empty butt faster than it goes out, the butt acts as a delay converting downpour into a trickle.
I do something similar with one of my water butts, rather than water going back into the downpipe when it is full I have an extra pipe leading from the same level as the input hole to a small wildlife pond. The overflow goes to the pond and on the rare occasion it fills to the max it simly runs out over a wide area. Since I've done it Ive never had to refill the pond except in one very long dry spell.
A water butt is useful for all sorts of things. Living in a very hard water area I always found washing the cars a real pain - one black, one dark red - they always ended up streaky unless you quickly manually dried with a chamois. Now I just use a bucket of water butt water and rinse with a watering can of the same - no streaks, loads easier and quicker. One neighbour who asked me why I was watering the car believed me when I said, deadpan, I was hoping the car would grow because we never had enough room for luggage. He thinks I'm half crazy, I know he is gullible.
You might look at your local authority planning map, usually very detailed maps are online. Zoom in and it will show boundaries and often who is responsible for the fence - it may be that it's their land and they simply put an extra fence in for appearances, useful to know regardless of whether or not you plan to allow water to flow into it. Its probably better long term to have it all on yoru side, you have control and if the landowner does want to do anything with the strip you don't have to worry about it.
Also - speaking as an old(er) person I don't think you are supposed to call them "old peoples homes" any more :)
That's very helpful, thank you. I see yer blue plastic tubs at 200L for £10 not far from me on FB Marketplace.
Here's an idea.
Yep, looks like doing something like that. Thank you.
I was going to call it an old g-i-ts home but I didn't want to be rude :D .
You could run the guttering downpipe into a waterbutt then by leaving the butt tap just slightly open with a short length of hose directed to the no man's land. Then any heavy rain would gently percolate away and do so after it stops raining such that the butt acts as a sort of buffer. This is assuming you don't have a gardening need for the water
edit didn't fully read post above........
Borrowed from the jokes page in case you need any ideas re guttering..........
There are different sizes of guttering, too. For a small shed you might prefer the smaller diameter piping - more in keeping with a shed's proportions. I think my local B&Q has it and it is a bit cheaper than "house size" guttering. This is what I actually bought for my car-port and shed project, but never got around to fitting it - that's a job for next year when I remove the roof and replace a few areas of damp OSB...
Found it here - it's called "miniflow" and is 76mm dia rather than 112mm...
https://www.diy.com/departments/flo...ound-gutter-length-l-2m-dia-76mm/81059_BQ.prd
Yeah all the pricing up I did was on the miniFlow stuff at Wickes/B&Q/Screwfix, but I didn;t notice that value pack, thank you.
Thoughts?
there is no such thing as no-mans-land in england. every square inch of land is owned by somebody or some- body
It's a useful phrase, though, for a small parcel of land that is fenced off, unused and not maintained by anyone. Of course somebody *owns* it, but if it is just left as unused then the term used would seem to fit, would it not??
Working on the basis you have a standard 8x6 shed the water off the roof in the scheme of things it's negligible. I would use black or brown mini guttering and just above horns ground level fit a shoe/ 90 degree bend - fit at ground pebble
Typo on phone time.. couldn't edit for some reason
Remove horns and pebble. Insert level and add pipe running under or through fence to no mans land to the middle. The water will disappear
I read that as
Working on the basis you have a standard 8x6 shed the water off the roof in the scheme of things it's negligible. I would use black or brown mini guttering and just above ground level fit a shoe/ 90 degree bend - fit at ground level, add pipe running under or through fence to no mans land to the middle. The water will disappear
Should say this :) . Cheers.
There's 3 ways of doing it:
1) Two sets of guttering, one on each side of shed, running to back of shed then each has its own downpipe straight down to angle joints and both going seperately through fence to no man's land. Price £50 not including half pipe guttering, 'cos that's bought cheap of FB and is same price no matter what scenario.
2) Two sets of guttering, one on each side of shed, running to back of shed then each going around back of shed to join at gutter level, one downpipe straight down to angle joint and then going through fence to no man's land. Heavier flow because only one downpipe serving two gutters. Price £40 not including guttering
3) Two sets of guttering, one on each side of shed, running to back of shed then each going around back of shed to join at gutter level, one downpipe straight down to 100L water butt (sadly, despite same price 'cos on offer, can't have 210L cos won't fit in space dammit). Hosepipe connected to butt tap at bottom goes through fence to no man's land to bleed off water when appropriate. Risk of 100L butt overflowing but friendlier on no man's land as gentle flow from tap, plus can reserve water if required. Price £61 not including guttering.
The stupid price of the angled joints and downpipes makes it tempting to just get the butt despite the overall higher price.
I may be overthinking this :D .
