steve66
Same breather membrane they use on timber frame houses, can pick up off
eBay
eBay
Doing this the shed windows would be over 3m above ground floor level. This doesn’t work for me for reasons outlined in the above posts.ok so it will require a step up into the shed but does that matter? In what way would it be too high??
90cm from the back to the frontWhat is the height difference over the length of the proposed shed. Are we talking half a meter at one end or less?
A number of better solutions than this have been discussed above.Its going to cost a lot to build a retaining wall properly which would involve excavation concrete steel reinforced footings, blocks backfilled with concrete and rendered over.
Yeah it’s a smallish garden and I have kids so it matters to me. Don’t really know what you mean by move the shed over but the spot I’m using is the only viable place to put the shed.In the scheme of things does it really matter if you lose a bit of lawn space? Why not move the shed over?
Youll end up more in the shed than playing in the grass, it never seems to stop raining in the uk.![]()
Well if you want to get existential about it sure, does anything really matter? Having a shed that fits into the garden well and maximises the space matters to me, that’s why I’m here.Seriously though does it really matter?
