RogerS
finneyb":3i2sxuzd said:phil.p":3i2sxuzd said:I see no reason why the electricity charges shouldn't be more variable. I have Economy 7 from necessity, but why can it not be more variable for all? The largest spike in energy use is between something like 5.00pm and 6.30pm - why is this not the most expensive power of the day? Much of the usage is people coming in from work and switching everything on, when much of it could be done by timers to run at the cheapest (or at least cheaper) time of the cycle. If the low is say 3.00am to 5.00am, that's when the washing machine should come on. Likewise tumble driers if they were made to be low fire risk - which they should be anyway. If the power used at peak were spread even by an hour or two it would be one fewer power stations we need - and we're coming to a time of inadequate generation so it should be seriously thought about now. I suspect ultimately that this is what smart meters are designed for, rather than to deter you from using your kettle full up.
+1
Also I am sure they could be programmed remotely so that those with a recognised need eg home kidney dialysis could have their supply safeguarded if/when cuts or brown outs occur.
Brian
Your faith in computer systems, the people who design them and the people who operate them and enter the data is touching, Brian. That covers switching the wrong people off.
Regarding 'brown-outs'...to specifically switch off only certain people on a circuit isn't possible. Well, if everyone had smart meters ........
