Teepeg
The team I had in to fit my kitchen last year made it look EASY ..
That s my point about designers don’t always get it right . The last one I was involved in was wren - the customer changed his mind a few times admittedly but the final design saw the washing machine moved to the opposite side of the kitchen to facilitate a dish washer . The designer then ran a 3 d simulation and said that everything is good and nothing clashes. Great I said but what about the cold water supply and more importantly what about the 1. 1/2 waste pipe that now has to be run around the skirting board ( on show btw ) on 2 walls .The first question to ask for a diy job us "where will the new stuff go when its delivered" - especially if it is pre assembled.
I fitted my own about 12 years ago - IKEA. Big-ish Kitchen. Just counted, 25 doors and 10 drawer fronts. Full height fridge and freezer, decided on freestaning - why make it difficult to replace stuff you know won't last forever. Took about 8 days spread over 3 weeks around work comittments. Not too bad a job, I made sure the cooker, hob and power points were where they always had been and carefully planned the rest of it. Although the house was only built in 1987 not much of it was properly square so there was a bit of 'messing about' to get some things looking good.
Some things to consider. When you empty the old cupboards you end up with an astonishing amount of 'stuff' which you have to put somewhere. Same with getting fitters to do it but diy takes longer and diy you also need your shed/garage/access to tools so can't put pots and pans there. On the plus side you remain in complete control. I did mine in sections obver about 3 weeks so we were only without the hob for part of one one day and the sink for a couple of hours. I made up the flat packs in preassembled sets in the garage - essentially a walls-worth at a time - but you do need plenty of space for that. A section of old stuff came out - put on the front drive, you need space for that - new went in. Every 2 or 3 days I had an old unit smashing session apart from the few I kept for the garage. and went to the tip, happily only a 10 minute drive but disposal might be more difficult in some places. I think the biggest challenge was managing workflow and space. (And losing pencils - in the end I bougt a dozen and left them everywhere.)
Nothing overly difficult in fixing the units, I made a simple marking gauge for the top cupboards mounting holes. Took great care with levels and used loads of those little plastic wedges because the floor wan't that even. IKEA cupboards don't have a space behind so give much more useable capacity but you do need to run all the pipework that was fitted behind the old units right down to skirting board level and along the bottom of the units - well worth doing for the end result. 12+ years on they are still like new so happy with quality. The scary bit is at the very end, drilling and fitting for all the handles - no going back - but I didn't do anything stupid like putting one on the hinge side of a door or having them 'clash' when open. I made a drilling guide and checked, checked and checked again before making holes.
Tiling can be done 'at leisure' when the kitchen is back in use. Happily the family went away for 3 days soon after completion so I just sat and tiled, grouted, tiled, grouted drank tea, tiled, grouted .... etc.
If you get professional planners/fitters do take your time trying to imagine everything in use. Imagine yourself getting up and making tea, imagine making sunday lunch with visitors. A double oven - do you put it so the bottom is at worktop height in which case a shorter person may have trouble with loading the top oven, or half a unit down which might be awkward lifitng things out of the main oven. How high and how tall should the top cupboards be. Personal choice and we all differ, just think it through. Don't leave it to the salesperson. A relative has a new multi ££££ flash looking kitchen, great but if you take a heavy hot casserole out of the oven you have to carry it past the freezer and fridge and round a corner before you find a place to put it down. A pain if you are just taking it out for a stir and check. I suspect the designer had never cooked anything. My neighbour had a JL kitchen planned and installed a few years back - including one of those fancy ice making fridges. Sadly the designer (dragger of drawings round a grid to make a pretty picture to sell you stuff) neglected a water or power supply. It was on the opposite side of the room to all the plumbing, no nearby sockets. It sat empty and unloved until they came back 8 weeks later and ran a water pipe around the ceiling and stuck coving up and brought power through from the other side of the wall. "But you signed ot off sir" "But it's not my job to check your designer isn't an silly person". So think detail and think about how you will use it all every day.
May I suggest rather than 150mm/6inch up from the worktop place them 100mm/4inches down from the underside of the wall cabinets. You will always be able to get to them when the worktop get filled up (it will!).>>snip<<
A tip for you. If you're putting electrical sockets in make sure they are at leat 150mm up from the work top surface as most modern kitchen gadgets' plugs, have strain relief glands that don't appreciate being bent at right angles if the sockets are too close to the work top. Ask me how I know.
Good luck
I am surprised given the enthusiasm for second hand tools on here that nobody else seems to think the second hand kitchen option is worth considering. Of course I don't know where they are based or the style they are after, but a very quick eBay search throws up:Son and his partner's new home needs a new kitchen. They're tight on budget having bought the house and so want to fit themselves.
They've not got a huge amount of DIY experience, but are smart and detail conscious.
Feasible? Sensible?
My feeling is that they'd be ok - but it's not something I've ever done myself so that's just a guess. I can lend a fairly full suite of tools. I think they're looking at Howdens or B&Q or IKEA or similar - any reccos?
Would be interested in any first-time-fitter experiences!
