All very illuminating. So, if I'm reading this correctly, I'd probably be better off even with a couple(my 4kw inverter is 24v in)of 50ah LFPs, than I am with my 2 130ah EFBs? Worth considering, especially as I could parallel up another pair, if finances allowed.
Well, the LYPs I run come as a single cell, rather than a '12v battery' (although LFP is available as '12v' or '24v' batteries as well as single cells afaik there are no manufacturers making LYP 'batteries' at all, there's only a handful making LYP at all), with an inbuilt BMS in the battery as well but not all are capable of being run in series though, some are, some aren't, depends on the manufacturer and their BMS
So you need 8 cells in series to make a 24v nominal battery bank...
A 24v 50Ah LFP has a theory/label storage of 1.2kwh with a practical storage of 0.96kwh at 80% DOD (15 years lifespan), your 130Ah EFB's have a theory storage of 3.12kwh with a practical limit of 1.56kwh (3-5 years lifespan) so not quite equivalent storage
A 24v 78Ah LFP bank would give you the same actual storage as your 130Ah EFB for 15 years, or a 24v 84Ah LFP again is the same actual storage as the 130Ah EFB for 20 years... (but remember your EFB will last much less at that 50% DOD...)
remember, the 'theory' storage is V x AH
So for both its 24v x 130Ah (3.12kwh)
But for L/A its practical storage is 50% DOD (0.5x label storage) is 3-5 years (at 1.56kwh usable), at 25% DOD (0.25x of label storage) 5-7 years (0.78kwh usable). and 10% DOD (0.1x label storage) its 8-10 years (0.312kwh usable)
LFP has the same 'label' storage so still the same there...
But you get that 80% DOD (0.8x label storage) for 13-15 years (2.496kwh usable), or 70% DOD (0.7x label) for 18-20 years(2.184kwh usable)
But yes you can use a smaller LFP Ah capacity so you get the same actual storage as the L/A EFB (but it will still last far longer in service life than the EFB will)
A LFP 78Ah will give you that 1.56kwh of actual storage for 13-15 years, and a 84.5Ah one will give you the same 1.56kwh for 18-20 years as the EFB for 3-5 years at 50% DOD
The theory 3.12kwh 130Ah EFB at 10% DOD will last 8-10 years but only has an effective 0.312kwh of actual storage, where a LFP of the same actual storage capacity of 0.312kwh is only 15.6Ah with a service life of 15 years or a 16.8Ah LFP for 20 years
It all depends on how hard you drive them- L/A need BIG banks to get long life... and although they are cheaper initially to buy them, buying ten times as much of L/A to get half the service life of a lithium that only costs twice as much per AH- see why I said it makes economic sense to go the lithium route????
That's why you don't find professional installs of L/A any more...
