Been working on a carving for an auction this weekend. Have tried to use the natural features of the wood to influence the design. Finished with intrinsic dyes, some metallics, shellac sanding sealer and wax polish.
Intended to be a tactile ornament rather than a gunner’s decoy!
It has taken about 3 weeks, have really enjoyed the process and will be sad to see it go.
I will use something a bit easier to carve if I ever do another, but it does feel nice.
It is a Spectacled (or Bronze-winged) Duck. An aggressive species from South America. The auction is for the British Waterfowl Association.
View attachment 198170View attachment 198171
View attachment 198172I will use something a bit easier to carve if I ever do another, but it does feel nice.
It is a Spectacled (or Bronze-winged) Duck. An aggressive species from South America. The auction is for the British Waterfowl Association. View attachment 198167
That’s so realistic I thought the top picture was a reference photo of an actual bird you were working from! Great job
Pinned tennons ocassionally get used in my pieces but I have no proper draw bore pins. Ray Iles sells them but at £75 a pair, which seems a bit expensive for two tapered steel rods with handles on. I keep meaning to grind some steel bar then make the handles meself but the grinding time would be long and I have no means to do it other than by-eye so they'd be wonky. Still, one day.
I like them handles. I've just got into carving handles albeit with proper brass ferules mounted on the handle ends, cut with a dowel maker in the drill press on the handle blanks before I start knifin' at them.
What size of taper pins do you need I have some about 80mm long x 5 to 7 mm taper.
That is unbelievable, wow! The way the ducks head appears from the wood in the half finished state is like, “hello”.
'Morning Phil,
I've been trying and failing to make the larger scale pins (for10mm dowels/pins) as I only use draw-bored M&Ts on larger items, really. I have pinned smaller M&Ts but not via drawboring (off-setting the tenon and mortise holes) as the pinning is more decorative than functional in those smaller things. But thank you very much for the offer.
I honestly thought that was a real duck when I first saw the picture, astonishing work that!
In-the-round carving frightens me a bit but if my attempts to take up carving take off that duck is the very emblem of the sort of thing I'd like to be able to do - natural forms but also the painting. I have read that the great majority of older carvings in wood evolved as painted items rather than being left as bare wood. The current carving-in-the-round tradition seems to be mostly using light and shadow to "paint" the bare-wood carvings but your duck illustrates just how good painted carving can be.
Morag,
I completely agree with CaptainBudget!
You are a very gifted carver! The bird is exceptionally life-like, similar to the fish you carved on the box you made for the Secret Santa exchanges...
Outstanding!
Wow Mo that's unbelievable 😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍😍
Seriously good. The raw wood carving was good but the colours and feather texture make it very lifelike. (y)
Been a busy couple of weeks but I managed to get my van racking finished & installed.
I cut a hole in the bulkhead to allow long lengths of pipe etc to pass under the passenger seat, this left a metal edge so to give protection I made a frame to fit in the hole.
This is it installed
I made a second racking unit with a top shelf
Here that is installed complete with a side shelf
Last off I made a top shelf for the racking I made a couple of weeks ago
All fitted
I’ve been using the new set up for the last week & it seems to be going well, I’ve a couple of tweaks to make but those will be done at a later date as I’m busy working on a shed at the moment.
