Evening SledDriver
Thank you for sharing all your info/updates on the restoration it has been soo informative. I have recently come into possession of much newer model of the Meddings Driltru...Feb 64
I have started to dismantle and love your 'placing on paper and writing what/where' technique. Have copied and are near completion of the dismantling. I had the exact same problem with removing my pulley attached to the motor, the gib head key was damaged. So far I have noticed two things missing and one big problem.
Missing is my depth gauge and the chuck key, both I can replace. The problem was the motor might be dead, first time I turned it on, it started for about 5 seconds and then stoped. Next time I changed the plug fuse and tried again. Tripped the garage and the whole house, my better half was not impressed, it was late at night. The cable seem damaged, so I have purchased replacement and finger crossed replacing it should work. Found out a neighbour wires motor for a living so he might be able to have a look. Going to bother you with a few of questions-
How are you getting on with the rewiring?
Are you changing the bearings in the motor?
The new bearings you already fitted, did you get from Meddings? what size are the? How much?
Thanks again for sharing all your hard work, you have done an amazing job.
Michael.
Hi. Thanks for your message, I'm glad you're making good progress on your drill.
Regarding the rewiring, I replaced the old cable with modern 1.5mm 3-core, but my knowledge of how to do so was just a case of taking plenty of photos prior to removing the previous wiring, then being careful to put it all back together in the same manner. I've attached a few photos I took during the process which might be of some assistance to you (to see if yours is wired the same). The first two are from the motor itself once you remove the bottom access plate;
Edit: I see your switch is different from mine! Mine has 4 positions - two of them on, two of them off. I have no idea why, as yours appears to just have two options. So the photos below likely don't bear much relevance.
This first image is what you're presented with after removing the access plate. The first wires to remove are the 3-core from the cable which enters the side of the motor through the rubber grommet you can just see in the bottom right of the photo (the other end of this cable goes into the switch);
This second image is what you see when you've removed the switch/motor cable, and you're left with the connection from the windings; I can't tell you the orientation of each wire (i.e. which black wire is which), because I just marked one of each with paint pen prior to disassembly and replaced as appropriate. Note that all of these wires must be disconnected prior to taking apart the case.
The next photos are from the switch.
The first photo is how the cable from the motor (from the first photo above) attaches to the switch;
This next photo is how the wall power cable attaches to the other side of the switch;
Not the best of photos but short of taking it apart that's the best I can suggest. You've probably got a short/ground fault somewhere? I know very little so your neighbour might be the best bet.
As for the bearings, I replaced all of them on the drill and motor. I didn't use Meddings for any parts, I just used one of the many websites selling bearings and other engineering parts. When I removed the bearings I made note of their markings and googled their replacements. I was in two minds about whether to use shielded/sealed bearings, but in the end I used a bit of a mixture of both depending on availability! I used sealed bearings in the motor as it was such an arse to get apart I didn't want to do it again.
I'm afraid that I can't remember which bearing went where, but I'm fairly sure that the entire thing was covered by the following orders;
- Two LJ7/8ZZ Imperial Metal Shielded Deep Groove Ball Bearing 7/8x2x9/16 inch (I think these were the 2 bearings just underneath the pulley in the head)
- Two SKF 62032RSH Rubber Sealed Deep Groove Ball Bearing 17x40x12mm (I'm fairly sure these were the motor bearings)
- Two LJ5/8ZZ Imperial Metal Shielded Deep Groove Ball Bearing 5/8x1-9/16x7/16 inch (I think these were the spindle bearings)
I ordered everything from simplybearings.co.uk
As far as I can tell those are a direct replacement for those used in the drill - at least they all fit for me.
I hope this is useful!
