J-G
I said that I only had Tufnol at 10mm thick but thinking 'outside the box' I also have Acetal Rod on the shelf in various diameters - including nominally 28mm which is 1.1023 though it is in fact a little 'oversize'.
Acetal is an industrial plastic just like 'Delrin' but Delrin is DuPont's trade name for it.
Realizing this made me think to break out my Gear Hobber which I haven't needed to use this year since I've been getting to grips with larger gears on my new (to me) CNC machine.
The result is that I have made you a length of 20T gearing which I can cut down to a pair of ½" thick gears.
I've made the bore 10mm because that is a standard arbour I have for my Hobber and I assume that you have the means to bore out to the diameter you need - that also makes more sense because you also have the spindle to fit it against. No matter how accurately you measure the spindle it would still be best for you to do the final fitting empirically.
Send me a PM with your address and I'll get them cut to width and pop them in the post.
