OPJ
Eric The Viking":1p54d8ob said:Can anyone suggest a good non-payment source of rubber sheet, to make a skirt for the bottom of the up-and-over door? Half the fun of this is doing it on a near-zero budget!
Last year, I bought one of these from Toolstation (I'm sure they were £4 cheaper?). It works well and has made a difference - of course, if you use the same door for access, you're still going to have some trouble with the cold... Only problem is that the concrete below the door dips slightly in the middle, meaning some draughts and water creep in where the excluder doesn't quite reach.
It might also be worth looking for a brush-type excluder, as opposed to something with a rubber strip - I think Screwfix used to do them? While you're budget approach is commendable, £16 isn't likely to empty many bank accounts.
Ventilation can be higher up as well, which should help to keep your toes warmer! :wink:
