Steve Blackdog
eggflan":364t9prq said:I use this
It may not look pretty but it gets my workshop toasty warm , oh and it was free and is free to run 8)
Did that used to be a calor gas bottle?
eggflan":2fg0ywww said:It was until my angle grinder and jigsaw got to work :lol: , this was a prototype one that i ended up using so just kept it , ive since made a few for friends :lol:
big soft moose":3kq4u7h3 said:http://www.stonecarve.com/woodburners.html
tomouse":2sd57830 said:After using a whole bottle of gas in one week, costing £45 i decided to make my own heating solution.........
A bit of cutting with a 5 inch grinder, some old T bar hinges and some welding and i ended up with this
Works a treat....
EDIT: why won't my pics work??????
its the sp;am trap - it will dispear once you have three posts -
Eric The Viking":2lzeeaxh said:T'other thing is sorting out the drafts. Can anyone suggest a good non-payment source of rubber sheet, to make a skirt for the bottom of the up-and-over door? Half the fun of this is doing it on a near-zero budget!
softtop":q6936sb3 said:Has anyone used one of those tubular heaters and will they actually do anything other than take the worst of the chill off in a garage?
Many thanks,
Henry
9fingers":1xug3obg said:Eric The Viking":1xug3obg said:T'other thing is sorting out the drafts. Can anyone suggest a good non-payment source of rubber sheet, to make a skirt for the bottom of the up-and-over door? Half the fun of this is doing it on a near-zero budget!
Ask round at tyre fitting bays. They usually have the odd inner tube around in the rubbish. The rubber is quite thin but can be backed up with something to stiffen it or use two layers glued together.
I always keep an inner tube 'in stock' as they are good for punching out sealing washers and even certain sorts of gaskets.
Bob
Pete Maddex":1teyj5pd said:Hi,
I used plastic DPC in a U shape pop riveted to the bottom of my garage door, its lasted years and works well.
Eric The Viking":2gza7gk9 said:Pete Maddex":2gza7gk9 said:Hi,
That's a grand idea!
I'm not disparaging those who've suggested inner tube. It's great for other things (record player suspension mountings and water seals, to name but two!), but the problem is that it's a long straight line to seal. There's a curve on inner-tube that would make it a bit tricky.
DPC sounds like a brilliant solution.
9fingers":3cohg0fx said:I agree the DPC should do the this job well but should you ever want a long flat (ish) strip from an inner tube then it is possible to cut a helical strip from a tube. Tricky but possible!
Bob
