Double garage heating
I got a diesel cab/camper van heater off ebay, about £70. I've divided my double garage into a smaller 5 x 3m workshop and it warms that up from 2 to 20 degrees in about 10 mins. If I reduct to th E main garage it struggles to get to 15 degrees but that makes working out there quite comfortable. With the oil pump on full chat (so max output) to get the place warm then throttled down, I reckon it uses about a gallon of diesel a day. I get red diesel off a farmer mate of mine so it's about 80p/litre. It sucks combustion air in and exhausts to the outside and recirculates warm air.
A very efficient way to heat. I have one in my motorhome. There are also portable ones for larger spaces. Believe it or not here in Australia from about April to October inland it can get very cold at night. Over 20*c daytime but below zero at night. Heats up the motothome in a couple of minutes. Anyways its the hot part of the year now and most days I cant do much in the shed. Seriously thinking of a small AC unit to keep the shed cool. May need more power supply to run it however. Different ends of the same problem and isnulation is key to both.
Regards
As someone who works in their garage and is all too painfully aware of winter temperatures I can suggest the below. My garage walls/roof appear to have the insulating properties of tracing paper and I have no heater:
1. Drafts -find any gaps/holes/etc. in the door frames, walls, etc. and fill with expanding foam. Doors you can use neoprene strips to fill any gaps around the frame, and draft excluders at the bottom of the doors. If it's a UPVC door you shouldn't have this issue. Brushes or neoprene strips on the underside of your doors will help as well...
2. Thermals. A decent base layer T-shirt and trousers makes a HUGE difference as you don't feel the cold anywhere near as much. You can get these for ~£10.00 each
3. Tea station. Warm your hands up on a brew as required; cheap kettle and a mug is maybe £20.00? The Power of Yorkshire Tea will also improve the quality of your work as you go ;)
3. Hand Tools! I've hand-planed in -5C before and dropped down to a T-shirt after 5 minutes because I just got too warm.
Others have suggested insulation and heaters, if you can afford to do so then go for it but a garage is unlikely to ever be "toasty warm" unless someone has built it extremely well (seems to be very unusual in the UK...). I'd suggest trying the above first as you'll be maybe £50.00 out of pocket if they don't work.
I recently moved into a new build and my double garage is adjoined to the bungalow. There was no insulation in the garage loft, but now it is the same standard as the rest of the house. I've also put insulation on the walls and they were then covered with OSB. The floor is also insulated and covered with construction ply. The crowning glory was having a two-metre radiator fitted, from the main central heating, and now it is the same temperature as the rest of the bungalow. Also, we haven't noticed any real change in our heating bills.
how do you prevent damp developing in the cavity behind the insulation and the outer wall
I've been thinking about getting one of these.
Just an observation. It's about 5 C outside here, according to the outside thermometer.
Just went into the double attached garage for something.
8 C. That wall's insulated as well. So even a little bit goes a long way. It was noticeably warmer in there than outside.
Adding to the list others have posted on how to stay warm
I have a Charnwood dc50 dust extraction when in use this produces one heck of a draft.
I now separate the garage half way , with wind brake netting . I have the heater my side and put the dust extraction unit on the other just having the hose by the lathe...
No more cold air blowing on my back and side
I have been working in an unheated church fixing some windows for the last couple of months. As you can imagine it is impossible to keep the entire place warm, especially once you take out a 3 metre high window.
So, in order not to completely freeze I bought a couple of infra red heaters which come on tripods and I can point them at the workbench and me and stay fairly toasty.
I was a bit sceptical at first but I had to do something so tried them out, they are actually very good. It is a direct radiant heat and though it doesn`t heat the air it warms the bench and tools and me quite well, they have 9 heat settings and usually number 5 is enough.
They are these ones https://castleheaters.co.uk/products/nebula-2kw-infrared-heater
The tripod is surprisingly good for the money, only thing I would improve would be a swiveling head so you could turn it 90 degrees for better storage when folded up, I might adapt this if i get around to it.
Ollie
Ollie
We had radiant heaters where I worked at one time. They work well if you're in front of them as you say.
I use a single car garage and like Katomi woodsmith covered the garage doors (rolling shutters in my case) but used an old pair of curtains. It made a big difference.
Moving later in the month, I think I’ve got my work cut out insulating this double garage to become my next workshop. 11ft high and steel roller doors. Another six feet of open rafters above.
Centre partition boarded one side.
    980.1 KB
    1 MB
    1.8 MB
Insulation, Insulation, Insulation. When we moved into our place the large double garage was uninsulated. Freezing in winter & too hot in summer. A local guy used to sell celotex rejects & i lined the garage to good effect. Terminal woodworm in the roof & the asbestos panels starting to leak meant a full re roof job 4 years ago, this was done in steel profile insulated panels 60mm thick. While i was at it new steel doors were made & fitted & the insulation upgraded & windows double glazed.
It wasnt that cheap to do but cheaper in the long run than trying to heat it!
I now have a lovely warm workshop, cool in the summer warm in the winter.
A 4kw woodburner keeps it toasty warm even in this sub zero weather. If its not too cold an oil filled rad does the job. Condensation is a thing of the past & my machines & tools do not go rusty.
