try this link to fix your veritas. A lot more constructive post then, " I wouldn't waste your time on a veritas marking gauge" lol.
I used to spend a day or more marking up for e.g. 5 sash windows. An unreliable gauge would be a disaster.If you're marking a real piece of wood, to go into a real project (not spending a weekend playing with test boards) and a gauge fence slips you're going to leave a mark that you may not be able to remove within the confines of the planned thickness of the workpiece. This is no "oh, well, let me stop and fix my gauge moment." You may have ruined a crucial workpiece meant for a crucial place in the project, said workpiece costing four times the amount of some gauge if not more.
The chance I'm going to "fix it" and risk it happening again is virtually zero.
"This gauge no longer holds a setting..." "Buh-bye gauge." The first requirement of a gauge is that it holds where it is set. The second is that it has a facility to impart a mark on the wood -- pin, knife, wheel, or pencil.
All the video confirms is that the tool is fatally flawed -- the style, design, execution, materials used, and brand (same as the OP's). This should be the takeaway.
It's amazing to me how many people in the thread don't get how devastating a gauge losing its setting can be and just toss it off as a minor inconvenience.I used to spend a day or more marking up for e.g. 5 sash windows. An unreliable gauge would be a disaster. The trad woodies are 100% reliable and much nicer to use.
I would add this one. You can sharpen all your edge tools to the same angle at once. It has never been easier. And I know that Jacob loves sharpening jigs. The only caveat is that you need to use gravestone for sharpening, as for some people, it needs to be really wide to accommodate all their chisels and plane blades.Here you go Jacob. Some new and innovative marking gages that Lee Valley are having great success with. Even you can't argue about their brilliance and practicality.
https://www.leevalley.com/en-ca/afd/veritas-dodeca-gauge
https://www.leevalley.com/en-ca/afd/veritas-caliper-marking-gauge
Yebbut only 5 brass knobs?I would add this one. You can sharpen all your edge tools to the same angle at once. It has never been easier. And I know that Jacob loves sharpening jigs. The only caveat is that you need to use gravestone for sharpening, as for some people, it needs to be really wide to accommodate all their chisels and plane blades.
https://www.leevalley.com/en-ca/afd/veritas-honing-guide-mk-xxxxii
Yes, you are right, we should define a new measurement unit KPI. It stands for knob per inch.Yebbut only 5 brass knobs?They could have added a couple more for luck.
Stanley made a couple variations (I think) of a two-armed wheel gauge. One, the 91, thankfully did not feature brass. I don't know why anybody would want to resurrect these, even with supposed "improvements."The "Veritas Dual Marking Gauge" is interesting.It has three little knobs to go wrong instead of just one. It could have had five if it also had the micro adjusters. Can't have too many brass knobs!
At least they have recognised their knob prob and sell a little extra gadget ("shaft clamp") to keep the dual rods together with less slippage, hence the third knob.
It'd be hopeless as a Mortice Gauge as you'd have to stop and turn the wheels to face the other way to move from mortice to marking tenons, which is presumably why they can't really call it a "Mortice" gauge.
All in all it's a design disaster.
The normal mortice gauge (see photos above for for two typical examples) has no knobs at all but just one screw - this is because it is under the body and a sticking out wing nut could be a prob. The slotted steel screw bears on to a button inside and locks all three pieces together at once (the shaft, the body, the slide with the second pin).
The slide may have a knob adjuster but it isn't necessary to lock it - it's all done with the one screw.
It works really well and I've used them for many hours without any issue - except if you pull it all apart for any reason then you could drop the button and lose it.
https://woodworkersworkshop.co.uk/veritas-dual-marking-gauge/
Definitely not a mortice gauge then....
For those that use this gauge (I have one), the wheels are used one at a time, not together. If used together, the lines would be shallow.
That explains it! Not a mortice gauge but a "dual" gauge.Of course, this makes this mortice gauge easy to use as a double cutting gauge, that is, with dual settings.
Sorry Derek, missed this one......How many of your wooden mortice gauges allow you to first set the width of the chisel, and then set the depth of the mortice from the side of the stretcher?
