mudman
- Joined
- 11 Feb 2004
- Messages
- 1,243
- Reaction score
- 248
If the OP's post had been along the lines of "I want to buy a marking gauge and have been looking at the Veritas, what do people think?" Then your answer would have been relevant. Instead, as Mike said above you came wading in with your usual line of "Don't waste your time", and then instructed the OP to move to the more traditional equipment. He already has the Veritas, now he wants to know why it loses its setting. This is most likely a production defect as Veritas tools are some of the best around, but either way, your response was, as usual, a preachy pontification that doesn't address the real problem and is clearly designed to create an argument.Let's be very clear about this - it offered the simplest solution to a simple problem.
I will answer questions as I see fit. I have had experience of modern tools including a metal marking gauge which had similar problems and was unpleasant to use for long - I've had to spend many hours marking up.
People should concentrate on the message, right or wrong, rather than insulting the messenger, which just lowers the tone.
Answering questions "as you see fit" usually involves you climbing into the pulpit of "trad" woodworking and delivering a sermon to the congregation on how they should live their woodworking lives and espouse the benefits of the old ways and to avoid the evils of modern thinking. Usually with no relevance to what has been asked just taking any opportunity to preach "Jacob's Way".
There was nothing insulting in Mike's post, you are just displaying the current trend of being offended by anyone that stands up and takes an opposing stance and then to point a finger and scream some words ending in 'phobic'. I'm actually quite surprised at how much slack you are given and how you are allowed to continue like this. I am sure there are many members of this forum that don't engage and leave.
Anyway, I find it all very tiresome so I'm going to put you on ignore from now on and I suggest everyone else should do the same.
