Got this from our electricity supplier...
Your electricity meter is out of date and requires urgent replacement. We are required to do so under governmental regulation of the Electricity Act 1989.
The lifespan of your meter is set by the Office for Product Safety and Standards (OPSS). This is to ensure your energy is always recorded accurately so you only pay for what you use.
They've been hassling me to fit a smart meter for ages and I don't want to. So is this their latest wheeze at trying to get me to instal one ?
It isn't a 'wheeze'. When gas and electricity meter reach their 'best before date' gas and electricity suppliers are required by legislation to replace it. Here are some FAQs from BG - all energy suppliers will say the same:
Quote:
Meter certification:
Just like most things, your electricity and gas meters have a ‘best before’ date – this can vary between 10 and 40 years. As your meter gets older it may stop working correctly by running too fast or too slow, leading to inaccurate bills. When your gas or electricity meter reaches its best before date we are required to replace your meter. You can read more about meter certification on this government website:
Electricity meter certification.
How will I know when my meter needs to be replaced?
As your energy supplier we have access to industry data which tells us which meters are approaching their best before date. We check this list regularly and contact customers whose meter types are on this list, asking them to get in touch to book an appointment to exchange their meters free of charge.
Do you have to replace my meter?
Yes, we are required by government legislation to make sure you have a reliable, working meter.
You have told me only one meter has reached its best before date, will you exchange both meters?
Yes, if we supply both your gas and electricity we will exchange both your meters at the same time.
Do you need to change anything else?
No, we won’t change your tariff or payment method, just exchange the old meters for new ones.
What if I don’t want a smart meter?
Due to Ofgem regulations we are required to install a smart meter in customers properties when replacing a meter due to its age. If you’d prefer not to have a smart meter installed
live chat with one of our advisors and we’ll update your account.
End quote.
I've had smart meters since 2016.
The SMETs1 meters stopped working in 2020 so I had to read the meters myself. After a lot of badgering, I got them replaced with SMETs 2 meters, in 2022 but the gas meter wouldn't work in Smart mode, so each month I had to read the meter manually, which might not seem much of a task but it's sited in a meter box down the side of our house and isn't very accessible. I have to kneel down (not easy at 85, with having a knee replacement), to see the dial and operate the buttons. In bright sun, can only see the figures if I have a large towel draped over my head covering the open meter box to be able to see the figures.
The electricity meter is in a more accessible box, is powered from the mains as is the adjacent 'hub' which periodically sends smart readings to the supplier - in my case EON. The gas meter electronics is powered by a long-life internal battery, (ten years?), and should transmit smart readings to the hub, which then transmits them to EON. However, as the gas meter is about 10 Metres away from the electricity meter, the signals weren't reaching the hub. Fast forward to this month, and finally - after two years - three replacement electricity meters, four gas meters, both the gas and electric meters and the IHD ('In House Display') are working as the should. The latest gas meter is 'dual band' one, and runs on a higher radio frequency, which now reaches the hub.
Two representations to the Ombudsman (not impressed), two lots of £120 compensation (neither of which I sought nor expected), yesterday I thanked EON for finally succeeding, and had a reply thanking me for my patience, and another £50 compensation, not sought or expected.
I wouldn't try to convince anyone who has set their face against smart meters, to have them, any more that I'd try to convince an anti-vaxxer to get a Covid jab. If they refuse, it's not an issue for me. 61% of meters (34 million) in the UK are now Smart meters, with 30.8 million (54%) operating in smart mode.
https://assets.publishing.service.g...c5/Q4_2023_Smart_Meters_Statistics_Report.pdf
Anyone who wishes to take advantage of variable tariffs (such as charging an EV overnight at off peak times), will of course need a smart meter.
