No good for me.
Low mains pressure.
Two bathrooms, 10 radiators.
Is your heating on all the time then and just controlled by radiator valves?
Controlled by on/off thermostat in main living room with rad left open. You have to have at least one open when the system gets switched on - I presume - not sure what happens if you don't!
Could take the thermostat to another room if desired, but never do.
Thermostat is programmable but we never bother except it's currently set to come on if the inside temp drops to 13º which it never does, so it's just on/off and adjust rads if necessary.
Haven't had CH on since last winter so it just does DHW.
Have been room heating with wood stove alone - rocket-stove fashion i.e. small charge of small dry stuff burning fast for quick heat output. Can warm the room very quickly just burning a few scraps and bits of cardboard. Having to reduce the sizes in my log pile for faster burning. You can see the difference on the glass - it doesn't soot up like it used to as it's doing a faster and cleaner burn most of the time.
Also have insulation everywhere i.e. is most important issue of all and most cost effective in the medium term though I haven't done any calcs on that one.
Did calcs on DG - would never pay for itself, totally cost ineffective, though this may change with fuel costs of course.
