Random Orbital Bob
I thought he meant that too....then I thought what you did
Did you notice which section of the forum this was posted in ? I can't believe you're seriously suggesting using an Eclipse jig on a bowl gouge.Graham Orm":lttl3yxj said:I am now using an Eclipse jig on a diamond stone
Rhossydd":1t457hsn said:Did you notice which section of the forum this was posted in ? I can't believe you're seriously suggesting using an Eclipse jig on a bowl gouge.Graham Orm":1t457hsn said:I am now using an Eclipse jig on a diamond stone
It looks like the SPE is a seriously good bit of kit by the entire lack of negative comments here. The only downside is the initial cost, but they are really solidly built. The rarity and high prices they go for on eBay usually tells you that purchasers are pretty satisfied with them. I've just about given up waiting for one to sell for a significant discount off new, so will be buying mine new later this month.
But you can easily get away with a 6" grinder with a decent wheel if you're unsure about the investment or simply can't afford it.
Send me a linkDoofusme":2g6xcqkz said:You should buy my grinder outfit on ebay....
woodpig":3mf6umq5 said:60 grit on my belt sander takes metal off pretty fast but the real beauty is that I can change to 240 grit to get a polished edge. The only let down with the Pro edge is the time it takes to change belts. I don't know how long it takes you Pro edge owners but it only takes a few seconds on my belt sander. In fairness it used to take several minutes at least on my RP BDS250 until I modified it for tool sharpening.
paulm":2msxb27f said:Only takes about five seconds on the pro-edge, tracking always remains spot on for me too, haven't had to adjust it since initial set up a few years back.
Cheers, Paul
woodpig":32n8zr6q said:paulm":32n8zr6q said:Only takes about five seconds on the pro-edge, tracking always remains spot on for me too, haven't had to adjust it since initial set up a few years back.
Cheers, Paul
I think they must have changed the design then Paul because it used to take a few minutes to remove and replace the covers on the ones they had at work.
