Molynoox
Fair pointIf only there was a way to somehow add to the dimensions to make it bigger…![]()
I bought a pair of the UJK track clips a while back, but found them a bit of a pain to connect and disconnect to/from the dogs. On one of @petermillard ’s videos, he mentioned David Stanton’s rail clips. I’ve seen versions made from 6mm ply, and you can buy them from David’s etsy (Stanton Dog Locks Sold as a Pair - Etsy) store, but I made a 3D printed pair
They’re a mirror-image pair that slide in the rail’s t-track and secure the rail very well.
If anyone is interested, I’m happy to share the stl file.
I've had a few requests for the .stl file.Yes please, I would like a copy of the STL file as well.
I don't think I have had it long enough to give you a meaningful / accurate answer. But I'll have a goThat was very informative, thank you.
How often do you find yourself using the sliding portion of your mitre saw now you have the MFT setup?
I plan to get a MFT and currently have a standard mitre saw so I was curious if you could do without a sliding mitre saw.
Referencing to parallel rail guides If I have a lot of the same width long cuts to make, I knock up some simple gauge blocks to set my rail distance off the edge of the board just pop them on the board edge held with a spring clamp pull the rail up to it and off we go, for instance:The rail squares? Theres a lot of choices, ranging from 20 quid up.
If, in practice, a rail square is within a mm over 2.4, its worth the 240 quid in the long run..... but itd have to be that accurate or better. Of course at that length a parallel guide is the right tool, but how far do you go?
Very coolReferencing to parallel rail guides If I have a lot of the same width long cuts to make, I knock up some simple gauge blocks to set my rail distance off the edge of the board just pop them on the board edge held with a spring clamp pull the rail up to it and off we go, for instance:
I bought the TSO rails square but only use it for cutting the width of the boards.
The other site method I use for breaking down full sheets is a simple 1m x 2m (3"x2") timber frame that I set on trestles, then use the mft as and when for regular small cuts (good job I have a big van and work in big houses!!)
Another tip/item I use, for setting my flag stop's on the mft fence for repeat cuts, are simple offcuts of ply, cut them to the required length using the flag stop for reference, may have to move it to get it accurate, once it's correct screw on a stop that locates against the back of the rail, then if you want to go back later to make more of the same, no tape measuring needed, drop it on & move flag back up to it.
The main point I'm trying to make is that you don't need to spend out on gizmos & gadgets if you use a bit of lateral thinking, which to my mind is what woodworking is all about, and yes I have bought into this system, because my business needs have changed over the years, and will probably continue to do so, as I need to keep up with the times, as well as the demands and expectations of my customers.
Have you tried lifting it yetI had a mind numbing couple of hours this afternoon.... by the end I'd nearly lost the will to mft!
Just ordered these dogs off ebay to get me going.
not sure I want to carry that. perhaps some wheels like the kregActually, no. The frame and top are still seperate and I was half thinking of a slide in cleat system to lock them together or simply having blocks glued and screwed to the frame and screwed to the top so it can be moved separately..... i was pondering that while dying of boredom, but didn't reach a conclusion.... any input welcome![]()
Totally agree on keeping them separate but I don't think I would bother with anything more than blocks to locate it and hold for sideways movements. No need to screw down, it's not going anywhere is it, and then you can simply lift off the top when you want to move it.Actually, no. The frame and top are still seperate and I was half thinking of a slide in cleat system to lock them together or simply having blocks glued and screwed to the frame and screwed to the top so it can be moved separately..... i was pondering that while dying of boredom, but didn't reach a conclusion.... any input welcome![]()
I have just finished making option 3 but other than testing for square haven’t had the time to make anything yetSetup 1s - MFT + Bench dogs 'special'
This is a small, and probably very niche, workaround I used today, it allowed me to cross cut at 600mm on my 718mm MFT (normal crosscut capacity 550mm) and yet still line up the rail against the dogs, as opposed to using a rail square for the cuts longer than 550mm. I had to shift the rail to the left hand edge of the MFT and then adjust the workpiece so that just a small part of it was sitting under the rail. I wanted to trim off just a few mm, in order to get a perfectly square edge on the board before using the rail square. I only wanted to do this because I wanted to measure the accuracy of the rail square setup (#4) and to do that I needed a perfectly square corner on the board.
Here you can see the 5mm offcut:
It was actually a slight taper, maybe 1mm from top to bottom, so worth making the cut to get this perfectly square before I did my rail square accuracy measurements.
In this picture I have pushed the workpiece up to the dogs to check for square and as expected (hoped) it was perfect. I drew a little square in the top left corner to identify that this was the good corner, and the good two edges.
That is all the setups explained, hope that made sense. I find the table I included at the start useful for summarising and getting my head around the different options and making a choice between them depending on what I need to achieve. I'm still learning and although this is basic stuff for most people its all new to me and its not yet instinctive yet. Thinking it through like this has helped me though, and hopefully others also.
General observation on rail length
The 1.5m long rail is really quite annoying (across all setups) and I would like something more like 800 or 900mm long so it isn't hanging over the end of the table all the time. I still need a 1.5m rail for cutting full sheets down, its the perfect size for that actually, but I do have two 1.5m rails and when working with smaller workpieces, say 600mm or less, a smaller rail would be a nice upgrade. I am actually thinking about cutting on of my 1.5m rails down to 1.2m - this still gives me 2.7 total if I joined both rails which allows me to do a rip cut on a full sheet, but it reduces one rail by 300mm, which isn't perfect but it gets me halfway there and for zero cots or compromise.
Note: Its nice having two rails, as I can leave the rail square permo attached to one of them. Its pretty easy to remove it, but not as easy as not removing it.
My summary
Of course there are lots of other options that could perhaps take the best bits from each of these and hit the sweet spot for each individual user. For example maybe setup one but with a 800mm deep MFT top (instead of 718mm) would give a fully accurate 630mm crosscut capacity, without the need for an expensive hinge. Throw in some £15 rail clips and you have a fully functional MFT setup that will handle most tasks - it would also be inexpensive and could be the perfect entry model.
- Setup 1 is a good first option to get started with MFT as its accurate and simple, HOWEVER make sure you get rail clips (or make them) and also make sure you don't need to cut anything wider than 550mm, or this won't work for you.
- Setup 3 is a bit of a dream setup, except its not portable, it can't handle full sheets and the hinges are expensive. If you make the millard ply hinge and add it to a standard 718mm MFT it would solve most of those issues - with the exception that for full sheet breakdowns you need to measure and mark as per normal track saw setup.
- Setup 4 is a brilliant option if you want portability and regularly cut large sheets and / or dont need to worry about mm accuracy. Adding a repeat stop to this setup gives a really slick setup - fast and pretty accurate. Also note that 0.6mm over a 640mm cross cut is probably sufficient for vast majority of tasks including cabinet making
- Setup 5 is the ultimate workshop setup, but too big for site work IMO.
- Setup 2 is a total oddball and I haven't figured it out yet.
Anyway, I will leave it there for nowI am very interested to hear about any other setups I have missed, or more importantly for any corrections with what I have said.
Martin
