scooby
Axminster are pretty expensive now..There are a few items on my Axminster wish list that I cant buy elsewhere (chuck jaws, lathe stand and extension). After that, I'll be shopping around.
Late to the party but I have the Sorby Pro Edge which seems to require the DIY shims as getting plane irons square is not easy. Turning tools were brilliant in contrast.
Please could you explain or show how the DIY shims can be made and fitted.
Its most likely the issue AJB mentioned, the backing plate (platen) isn't exactly square to the tool rest. I noticed mine is like this the first time I ground a plane iron. If I slide the iron across the rest, keeping the same distance from the belt, at certain points it won't be doing much grinding. In other words, it won't grind uniformly.I also have the ProEdge and I’ve never managed to get a decent flat grind for chisels or plane blades but for turning tools it’s brilliant. Sorby support was next to useless, pointing to user error which it may well be but I had hoped for more help. See my post on the Sorby support forums.
Struggling to get a good edge with the proedge | Robert Sorby Tools Forum
The table unbolts at the left. I experimented with very thin card shims at first and this worked. I then replaced them with metal shims made from cheap feeler gauge. But the most useful thing is an accessory for the Sorby, bought on line, which is an adjustable square for the table which makes it very easy to get chisels and plane blades dead on square across the cutting edge. I will see if I can find a link. Edit: here Robert Sorby PESQW Proedge Premium Square Guide
Many thanks.for your replies. @AJB Temple, I have the PESQW and adjusted to get a 90 degree but this was trial and error and I lost quite a lot of iron. I thought that the aluminium backing plate was not well made and could introduce other errors. In principle this should not be the answer. The skew chisel guide can’t be adjusted although this has not been a problem so far, possibly due to it not needing to be exactly 60 degrees.The table unbolts at the left. I experimented with very thin card shims at first and this worked. I then replaced them with metal shims made from cheap feeler gauge. But the most useful thing is an accessory for the Sorby, bought on line, which is an adjustable square for the table which makes it very easy to get chisels and plane blades dead on square across the cutting edge. I will see if I can find a link. Edit: here Robert Sorby PESQW Proedge Premium Square Guide
It's only a narrow linisher For a precise flat grind you need a wide sanding surface and a seamless belt - or better still a solid disc with the sandpaper stuck/velcro on.I‘m not quite sure here, what bit are we checking for square? The PESQW compensates for the red distance not being the same. But the table could also be sloping so that it’s not square to the plateau as shown in blue (as if you were looking straight on) or are we talking about something else?
Can't think how a disc could be dangerous. Might scuff your nails a bit if you get too close I suppose.....
I remain in disagreement with Jacob that a disk is better. It is certainly less safe.
Tool rest is not accurate, as you and other posters on here keep pointing out.One of the main advantages of the belt system, apart from safe and accurate tool support, is it is dead easy to change belts.
No error in terms of woodwork tools and normal vision without magnification or microscope!Velcro adds cushioning, so can also introduce error. Depends how picky you are I guess.
The Sorby is great, but does have some annoying things that could be improved.
- A quick release for the table. Unscrewing the bolt on the side gets old really fast! (I change from the table to the fingernail gouge quite a bit)
- The handle of turning tools hit the motor. Fortunately some of my tools have the removable handle. But not all of them
- When grinding acute angles on a skew, the handle also butts into the motor. The fix for this is a table shim. But still annoying.
- A reverse. For the price, I would expect this. I'm making an assumption that this would be really easy to add.
- The angle adjustment of the belt should be toolless
Something that hasn’t been covered yet is actually the adaptability of the relatively simple system for adding your own jigs and fixtures.
For example, Nick Westermann sells a couple of add ons that make grinding his carving tools easy, and another for sharpening axes.
Axe jig:
https://www.hewnandhone.co.uk/product/axe-grinding-jig/
I have made a drill-bit sharpening jig for my proedge that is brilliant. This video inspired me, but I made up the angles and dimensions based on othe drill bit sharpening sources and measurements off the proedge:
My version made with some aluminium donated by Deadeye:
Test fitting before skimming the top:
Fitting up on the CNC:
Obviously this is made using the tools and machines that I have access to, but it could easily be made out of wood, or out of aluminium or steel with a file and screws. In this case of sharpening, repeatability is far more important than accuracy: drill bit charts show a 5-10 degree range for the same material, but the 2x flutes must be identical.
So is that less accurate than the DIY rest you might have on your DIY disk contraption or more likely you don't have one at all and just wing it so your comment isn't relevant.Tool rest is not accurate, as you and other posters on here keep pointing out.
