I have had a few apprentices in my time as a engineer, and turned out a couple of good engineers that I am proud of,
Filing low grade Aluminium such as LM6 will always clog a file, there is on way that seems to work for me, is Blind the teeth of the file with blackboard chalk, This "blinding" can also be used generally if you have a coarse file but require a finer cut, you blind it with chalk, as for file cards, something I won't use, nor steel wire brushes, they are both made from hard steel and do blunt files, If I use a brush it will be a brass brush, and not a brass coated brush
Buying Rusty Files for me is a bit of a no no, (you often see them at boot fares) the rust will take the sharpness from the cutting edge.
the two main things for filing other than the files is STANCE, file like you are a boxer with a leading foot so you can transfer steady weight to the file and you file with your arms, not your torso, the other is vice height, best control with filing is have the vice at the right height, generally, stand at your bench, put your index finger on your nose elbow tucked into your body pointing down, get somebody measure from the point of your elbow to the bench top, the top of the vice jaw should be at elbow height, this allows for good posture and control when sawing or filing
