Shooting board versus mitre trimmer for fine boxes
BradyS
UKW Supporter
16 Jan 2023
Romania
Good day!
As the thread name suggests it, I would appreciate some professional opinions from those of you who have used or are using ideally both of these options. I am looking for a long term solution regarding mitred joints. A part of my intended activity is going to be fine box making. I'm still learning to use hand tools.
Now I have neither used a mitre (guillotine), nor a shooting board. I don't own a low angle jack plane. Theory, yes, I gathered around both. Looking for more hands-on points of view here from you.
I won't have much use for shooting boards except for this purpose. Same goes for a mitre trimmer, although making picture frames would be lucrative in my area.
Since for me the costs of the plane, accessories and related jigs is similar to that of a used mitre trimmer (the tall, standing one, not the benchtop version), what do you suggest?
Much appreciated,
Brad
For boxes I’d go shooting plane as gives more versatility - doesn’t have to be expensive - a woody is easy to adjust to being 90degrees between side and sole and has good reference faces.
Guillotine trimmer all day long. The biggest, baddest, heaviest, industrial-strength, cast iron monstrosity you can lay hands on will run circles around a silly shooting board.
Each have their own pluses and minuses. Mitre trimmers are good for small stuff, for example you've a pile of doors needing mouldings, but they're not much use if the part is bigger than 4"
Shooting boards need constructed, and you have to get it 100% first off, which might require you to remake and remake again.
Thank you. I specifically mentioned the big size mitre trimmers. The model I'm considering has a cutting capacity of circa 180 x 100 mm, that's roughly 6.7 x 4 inches. And I've seen various information sources with renowed box makers who were using this machine for mitres.
I can imagine a mitre trimmer having capacity and leaving a polished cut but every one I've used has not been super accurate. I had a monster American one got the knives ground and it was awesome but it was never perfectly accurate and the blades soon went off sharp. If you could set it up perfect it would work.
I'd choose a perfectly set table saw 80t blade and a sled. Bang on every time both on angle and cut length(being jigged).
Don't forget flat and square and equal length is also important. The mitre is a very fussy joint for perfection imho.
A very good point.
I don’t see there being a right or wrong answer to the question of which to use..
If you want to create a mitre joint by pulling down a lever go for the guillotine. I’d say that takes less skill and agree with the comment of it being a one trick pony but it’s perhaps the most time efficient.
If you like the whoosh of the plane and the increased sense of satisfaction of having and using the skill go down the shooting board route.
There is more to making boxes than cutting miters. Plain miters can be cut in a variety of ways but how .will you strengthen them ? I notice an increasing tendency to use CA glue to hold them and then insert 2-3 mm slips of wood into router cut slots but I think that's a bit of a cop out. You would be better advised to look at the miter lock joints done on a router table which are a pain to set up certainly but very secure.
I would also look at the standard ' Lion ' miter trimmer which will cut very clean miters in smallish pieces for inlay etc.
I now use an American ' Miter fold blade' sold by Rockler in the US which does everything in one pass. You need a saw with a 5/8" arbour to use it unfortunately.
I've seen the mitre fold and heard its cool but I thought it was only for ply.
Does it work good for solid?
Is it cheap and easy to import?
Maybe a tool test needed here....hint hints....
I have a Morso guillotine, it’s dead on accurate producing perfect mitre joints. It was designed to make picture frames, and has a large capacity. If you’ve priced up picture frame stock you will realise that accuracy and right first time are essential. The blades stay sharp on mine for ever. I don’t use it a huge amount, but in eight years, it’s so far not needed the blades sharpening! The cut is still ‘mirror’ perfect. I can cut off a shaving to adjust a joint that’s transparent! If you have space in your workshop for one, I’d get one. I don’t make picture frames, and use it for all sorts of stuff.
Originally designed by a chap called Andy Klein to make boxes out of one piece of ply. However I found that it will cut clean miter fold joints across solid wood with the help of a sled. It's particularly useful for cutting veneered wood although you will probably want to insert solid inlays on the corners to protect them anyway. Lots of videos on You Tube showing it in use and Rockler will send you one from the website. Postage and custom charges will apply of course.
In some respects you have answered your own question, to my mind, If picture frames would be a better opportunity, I would look at box making in a secondary light and deal with them separately in the future.
