Too much of a faff. Look at the clip I posted; if the fence is 'out of kilter', remove it, take a few shavings as shown to make it true again, tap it back in place and test. Takes less than a minute and you're back in business - RobI recommend strongly using a sacrificial fence against your main fence using some toggle clamps to keep it in place. If the fence is then marginally out of alignment you can than shim it with pieces of plastic (I use bits of plastic document wallet like David Charlesworth taught). This is super quick and you can shim in any direction with this approach.
Nothing mythical about them. They are used by a lot of people and fulfil a useful role. I don't know where you get the 'thousands of posts' from, people may have some difficulties but usually sort them out pretty quickly.Repeating myself sorry! But shooting boards are semi mythical and in fact fairly useless. You can tell by the thousands of posts about the difficulties encountered.
They look such a good idea especially to beginners, but they just don't work well.
Two bench hooks will do the job, but you work to marked or cut lines instead of relying on accuracy of a shooting board jig.
No you've missed the point - you work to the marks, as precise and accurate as you can manage, whether with bench hooks or shooting board - they are there just to support the workpiece......
A couple of rough bench hooks may work for what you do,
Can you explain why a rounded bevel with an edge angle of 30º would be in any way inferior to a flat bevel, or double, triple bevel, with a 30º edge angle?.... Rounded bevel anyone?
I think the one missing the point is you and by quite a large margin. I don't think anyone said that marks are not worked towards, you can do it freehand if you want, creeping up on your mark slowly and carefully stopping frequently to check you haven't gone past it on the other side, or mark it up, line it up on the shooting board and a few swipes of the plane and you will hit your mark nice and square, quickly and with minimal fuss. Maybe you had some issues with your shooting boards. Perhaps if you'd been one of the thousands of posts others might have been able to resolve your problems.No you've missed the point - you work to the marks, as precise and accurate as you can manage, whether with bench hooks or shooting board - they are there just to support the workpiece.
Nope never said it would be inferior. It might be, it might not. I suspect it isn't as good as a nice flat bevel but without some quantitative testing, I couldn't say for sure. I've tried a rounded bevel. Didn't care much for it. Works okay on a OBM chisel but I'm happy with the bevels on my other chisels as they are. The point you've again missed is that no one really cares if you want to round over your bevels. If it works for you, go for it. Keep doing it and good luck to you. It might be inferior, it might not, I don't care. If someone asks how to sharpen a chisel, then fine, describe your method to them. You only need to do it once and then they have it as an option. What really gets irritating is the constant berating of others when they describe an alternative. Yours is not the only way.Can you explain why a rounded bevel with an edge angle of 30º would be in any way inferior to a flat bevel, or double, triple bevel, with a 30º edge angle?
No you can't, don't bother to try!![]()
I am actually which is probably why I've answered you instead of ignoring you as I normally do.You seem to be in rather a bad temper, not having trouble with your shooting board I hope?
PS working to marks should be very precise, but more importantly, accurate. Not the same thing.
You had to go there didn’t you…PS If someone is working from drawings, then they will need to be precise but will also need to mark up their work with accuracy.
I made a shooting board years ago when I was making a lot of small boxes (6" cube for jackinaboxes in fact) and it was a bit useful, but found I never needed it when I started doing more real joinery and furniture.Perhaps if you'd been one of the thousands of posts others might have been able to resolve your problems.....
You've missed the point again!Nope. I've tried a rounded bevel. Didn't care much for it. ....
Go where exactly? I didn't see the point particularly.You had to go there didn’t you…
The debate is widened to accuracy of marking out pencils vs knives, story sticks vs drawings,Go where exactly? I didn't see the point particularly.![]()
What about rods?The debate is widened to accuracy of marking out pencils vs knives, story sticks vs drawings,
