Busy day! Put up a shed. Then came back to this. I decided to try and make the fence removable so that I can make a 45deg mitred one next and interchange them as needed.
I used a squared peice of stock to act as a temporary fence for the No. 078 and set to making a dado to accomodate the threaded rod (M6 stainless). First time I've used a Rebat / Rabbet plane. I really like the results but I was struggling to get the channels square on the bottom of the cut, I seemed to be putting more pressure on one side of the iron than the other. Luckly I could just flip the workpeice over. More practice needed!
![20230522_111131.jpeg 20230522_111131.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140729-3e5b74c9ad8754059904a1d6b3bcc720.jpg)
Once the cut was established I didn't need the guide any more
Edit: I also planed a little more off the top deck stand-offs so that it's now a 4deg slope.
![20230522_135255.jpeg 20230522_135255.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140731-803bfd99d4bfad7f2bc933dc15e93003.jpg)
Really enjoyed using that. Then I planed a peice of softwood to the size of the dado / width of the cutter on the 078 and used this to sand out any wayward strands of wood
![20230522_140326.jpeg 20230522_140326.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140732-a64c943d0b0af3723a5d9adcf974d78b.jpg)
This worked really well so it's earnt a place on the plane-shrine mantle
![20230522_164836.jpeg 20230522_164836.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140737-42391f25edf712bc9d1ab1322a788183.jpg)
Then I took the laminated fence (Sapele - Maple - Sapele) which I glued up y'day... Edit: has a 4deg bevel planed into the underside so it effectively creates 90deg receiving for the future workpeice
![20230522_165155.jpeg 20230522_165155.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140740-595df87757999c43774de3fc6d9b1a59.jpg)
...and drilled 9mm holes in to accomodate threaded inserts. These were epoxy'd into the fence.
![20230522_131426.jpeg 20230522_131426.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140730-fff162a7cdf2df96bdbfec04db75c3e1.jpg)
![20230522_165147.jpeg 20230522_165147.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140738-f87647deb57d40be37bc6745c6724d6d.jpg)
and I made a doofer for the front of the shooting board. This has a stop to enable positive engagement with the board when clamping the fence on.
![20230522_165213.jpeg 20230522_165213.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140741-98a76c2ecbeb0cc322c23afe04a51a40.jpg)
then I put it all together.
![20230522_163716.jpeg 20230522_163716.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140733-1cebe3d19994e3f02d3f61d874f8f629.jpg)
![20230522_163752.jpeg 20230522_163752.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attachments/140/140735-a35d7579793a189a3c356e21421ffd66.jpg)
Edit - all I could find were these T-track M6 inserts, I'll order some nice M6 knurled thumb nuts at some point....
Later on I'll glue the top deck onto the shooting board with some dowels if I feel brave enough. I plan to offset the top deck a little to enable a bench dog location hole on the sideto help keep the board in place when using. There will be a bench-stop on the underside as well.
Thanks for all your discussion, helps me a lot!
