This is an opportunist thread that I'm writing in case it's of interest to members.
It comes about because, purely by accident, @deema and myself happened to see the SawStop stand at a trade show a few days ago. We got to chat with the MD and we observed the "sausage" demo.
As part of the demo, SawStop Europe MD, Michael, swapped out the used braking cartridge and blade for new ones, and offered the "dead" items to anyone in the audience who wanted them. I jumped at the chance so that you can see some of what we saw.
The disclaimers that come with this are :
I don't have a sawstop saw. I probably never will as I use a 750kg 1980's SCM industrial tablesaw that I refurbished and modified myself. Sawstop don't make saws like this and I could never afford a comparable Felder, Altendorf, whatever to replace it even without the added safety tech.
I absolutely believe in training, good practice, push sticks, etc etc as first line of defense. Second line of defense is behavioural safety - training and self awareness.
BUT
For those who can afford the extra line of defence that active safety technologies can provide, I'd commend them to anyone.
Here are a whole bunch of photos and some observations around that blade and brake that I brought home with me from the demo.
First, here's the blade and brake as removed from the saw.
The blade's the standard supplied 24 tooth 10" one. It's a relatively cheap blade. Expansion slots are there but nothing sophisticated. Carbide teeth are small. 3mm kerf. Plate isn't tensioned. This is a site saw blade. You wouldn't bother resharpening this, you'd replace it when worn.
The brake cartridge is the blue plastic housing, electronics inside, and the sacrificial lump of aluminium.
I believe the replacement cost of the brake is £80 something. If you send an used brake cartridge back and SawStop judge it to have been used to prevent an actual injury, they say they'll replace it free of charge.
The activated brake had three blade teeth embedded in the aluminium block. They were well stuck, I couldn't separate them by hand. I did hold the blade and simply hammered on the end on the aluminium block in the "reverse" direction and after a few blows, the blade came free. Here are the three teeth seen from both sides. The tooth with the most obvious marks and one either side. The carbide teeth didn't seem that worse for wear and I would have kept that blade for further use if it were mine, at least for rough work.
Replacing the blade and cartridge need only the tools that come with the saw and took perhaps 3 or 4 minutes, though this "depends". If you were unlucky, it might take you a while longer.
The brake is held in place within the saw by what looks like a special pin. This has to be unlocked (by hand) and pulled out first.
The nut is removed from the saw arbor using a spanner as normal prior to removing the blade.
The blade and the brake then have to be slid off the saw arbor and a shaft that anchors the brake cartridge. With parts to slide off two parallel shafts, the fit was tight after the cartridge fired and some prying was needed. It took Michael a couple of minutes. Once it came free, fitting a new blade and cartridge takes under a minute.
If you look at the first photo, it appears that once the aluminium block engages the saw teeth, only two further teeth, 1/12 of a revolution enter the block before the blade is brought to a dead stop. It's a 4000 rpm saw, so that's 60 sec / (4000x12) or one and a quarter milliseconds. You'd have to add to this the time needed for the electronics to react and that big spring to launch the aluminium brake into the spinning blade, but it's still pretty quick.
During the demo, there was a substantial "bang" when the brake triggered.
The alloy block is obviously designed to deform as well as be cut in order to absorb the energy of the spinning blade.
The brake block is bent a little sideways too.
BUT
