Router table and router combination?
Terrier535
10 Sep 2023
Lincoln
Hi all, I’m looking to upgrade my routing setup and get a decent router / table for cabinetry work. Space isn’t a problem and it will be used in a workshop, so main criteria are a decent sized table and fence. I quite like the look of the Kreg PRS1045 workshop router table. I had thought about making one but a decent fence and T tracks seem to add to more than this would be.
The next question is which 1/2” router to go for. I want top adjustment but don’t know how a plunge router such as the Trend T11 or Triton TRB 001 compare with a Rutland R15 router and lift. The Triton is obviously the cheapest way to go, then the Rutland followed by the Trend (or similar).
I’m trying to buy right and buy once, so looking for an accurate and easy to use setup that I won’t have to replace. Any suggestions as to what would be the best approach would be gratefully received. Thank you.
It may be helpful if you mentioned what your budget is?
I have the AUK 2400w router with Incra offset table, Incra router lift and Incra LS positioner fence. Quality is amazing and the accuracy to dial in the fence for repeat cuts is awesome. The whole kit came from Woodworkers Workshop.
With Black Friday coming up, you should be able to get some good deals whatever you go for
Thanks for the reply - I’ll have a look at Woodworkers Workshop. Budget around £1000 -£1200.
I’m considering selling some items you may be interested in. All purchased from woodworkers workshop within the past 12 months.
Auk router table top and fence £220
Muscle chuck extension £75
JessEm rout-r premium lift with Dewalt plate £400
NVR switch £55
Dewalt 625 router £150
Total new cost is £900 but I’d take off £200 for nearly new if you were interested. It would need to be collected or else have a look at shipping costs - heavy items.
NVR switch £55
Thank you for the reply and offer. I have looked at that table top and fence before as it looks like a good option, but have decided I really need an 800mm fence.
If you're after a proper setup, @Gary B 's setup is worth it. If you are a hobby user with occasional use, then go for either T11 or Triton on an Incra plate and mount it on any decent top for over the table adjustment.
@Terrier535 if you decide to go down the Triton route then take a look at this pre drilled Incra plate, this has both the fixing holes and provides access to the winder from above the table. The Incra Magnalock plates are the best on the market.
https://woodworkersworkshop.co.uk/incra-magnalock-router-plate-7518-t/
If you go for the Trend then this is the one to go for, again pre drilled for fixing and using the routers winder, currently on Black Friday sale.
https://woodworkersworkshop.co.uk/incra-magnalock-router-plate-621625-al/
Other things to consider are the 800mm fence and table top.
https://woodworkersworkshop.co.uk/auktools-professional-router-fence/
\https://woodworkersworkshop.co.uk/auktools-800-x-600mm-router-table-top/
If you need any assistance or a package price please give Jim or Andy a call on 01684 594683 or email them at [email protected]
Peter
An important thing to be aware of regarding the T11 inverted is it can develop a speed fault. Im not saying it will happen but it definitely can.
There's a thread here describing the issue. https://www.ukworkshop.co.uk/threads/router-woes-anyone-else-with-a-t10-t11-or-dw625-had-this.57533/
I found that thread as I had a T10 (practically the same as T11 minus the above table adjustment) and it developed the fault after about 10 minutes of being inverted. At the time, it was only a couple of months old and worked flawlessly hand held. After removing from table, it eventually starting working again hand held so it was highly likely to be the same problem Eric had. I sent it back, got a replacement and never used it in my table until I sold it. It is an excellent router hand held, I must say.
my thread https://www.ukworkshop.co.uk/threads/trend-t10-speed-problem.144784/
Another T10 thread https://www.ukworkshop.co.uk/threads/trend-t10-problem.85305/
I previously had a Triton MOF001 in the table and it was absolutely fine, all the router table features were great. For some reason, the triton became really noisy with a bit of vibration when using 1 specific cutter (Wealden top/bottom bearing template). That's the reason I temporarily swapped the Trend on to the table. That cutter was fine in all my other routers so not sure of the issue with the Triton.
Edit; I forgot to add. When I was going through the replacement process. I received an email from the supplier (I think the wording came from Trend themselves) where they listed possible causes for the issue. One was using the router inverted. With the subsequent issues of dust entering the large air intakes near the collet and/or the speed sensor slipping down.
Yes I am still on the fence, upgrade my router table or go for the spindle moulder knowing that some can take my existing router bits.
@Terrier535 there are many good post on this subject, I have the Triton in a Jessem Prestige lift because it was originally in a Kreg plate I do not have what I consider the best setup because for that you do not want a plunge router hung upside down in your table. It is also cheaper to get the decision right and just go for it rather than itterate towards a goal as it evolves as many have discovered, but do not overlook the spindle moulder.
For a good router setup look at Jessem or Incra lifts with a router motor like the AUK
https://woodworkersworkshop.co.uk/auktools-2400w-fixed-base-router-remote-speed-control-and-nvr/
This now leaves the question of the fence and this is not so easy, I like the Incra positioner with the fence
https://woodworkersworkshop.co.uk/incra-ls25-positioner-super-system-with-wonder-fence-635mm-metric/
This can be used on a home made top with 20mm holes like the hooked on wood bench.
Some prefer the Jessem fence with the slide 2 mechanism, there is no right or wrong answer but the quality is really top notch.
