DomP
I can easily move it further than 1m
Don't know where you read that but it wasn't the regs. Gets interesting above 15m2.As long as 1m from boundary upto 30m² doesn't require regs is what I've just read
Planning portal, I'll call my local planning office to confirm thoughDon't know where you read that but it wasn't the regs. Gets interesting above 15m2.
, the relationship of reinforcing cover to concrete strength is a new one on this Ove Arup trained ex Chartered Structural Engineer,
https://www.planningportal.co.uk/ap...ulations/exemptions-from-building-regulationshttp://www.legislation.gov.uk/uksi/2010/2214/schedule/2/part/6/madeDon't know where you read that but it wasn't the regs. Gets interesting above 15m2.
And even better if you use polythene sheeting on the inside of the boards as you get a nice finish on the concrete and the boards are kept clean.I used scaffold boards for the formwork as they can be useful afterward.
Yup. As I say, just have a read through the regs. But also speak to your local BCO because their interpretation of non combustible is what matters (which you are doing so that's all cool)https://www.planningportal.co.uk/ap...ulations/exemptions-from-building-regulationshttp://www.legislation.gov.uk/uksi/2010/2214/schedule/2/part/6/made
CLASS 6
Small detached buildings
1. A detached single storey building, having a floor area which does not exceed 30m2, which contains no sleeping accommodation and is a building—
(a)no point of which is less than one metre from the boundary of its curtilage; or
(b)which is constructed substantially of non-combustible material.
2. A detached building designed and intended to shelter people from the effects of nuclear, chemical or conventional weapons, and not used for any other purpose, if—
(a)its floor area does not exceed 30m2; and
(b)the excavation for the building is no closer to any exposed part of another building or structure than a distance equal to the depth of the excavation plus one metre.
3. A detached building, having a floor area which does not exceed 15m2, which contains no sleeping accommodation.
That is the actual legislation - so, point 3 is a generic default if below 15m2
point 1 allows you to go up to 30m2 as long as it is not used for sleeping and also above 1m from boundary (or built substantially from non-combustible material)
point 2 is probably not relevant
All of this is class 6 exemptions from building control and is the legislation
not hugely complicated...
build up to 30m2 if you are 1m from the boundary or substantially non-combustible
above that, building regs come in...
Where did you read that?If you have not got neighbors or a highway on the boundary then I think the poster is correct about the 30m3 footprint for regs and 4 m to ridge. I have certainly built garages and sheds for people on that basis. The fire regs aren't easy to interpret and height is a factor, you can certainly have a six foot wooden fence next to an escape route
I am no planning expert but if you where next too the beach or a large river you would have no neighbours on the boundary. (apart from the crown on the foreshore and who ever owns the river but!). Other wise you always have a neigbour is just a matter of what they are currently using the land for.Where did you read that?
Thankfully not arable land and what I meant by no neighbours was that I have no domestic property neighboursI am no planning expert but if you where next too the beach or a large river you would have no neighbours on the boundary. (apart from the crown on the foreshore and who ever owns the river but!). Other wise you always have a neigbour is just a matter of what they are currently using the land for.
Not sure how the builder and owner of a garage would fare if a farmer had his corn field burnt if the garage did not comply. Would their insurance pay out, I don't know.
Needs to be 2m away from boundary if you want to go above 2.5m height, that's according to the permitted development guidelines.My new intended location will be 8-10 metres from a field and can be over 1 metre from a hedge that runs along a country lane. Again I will contact my local planning office but I don't see an issue. I'll post a plan
You deliberately miss interpreted my previous post on purpose I assume as it meets your agenda, you have latched onto cover and I SAID 20MM AGGREGATE, sorry to shout, but you seem you have difficulty reading what is written.I missed out this point
from EC2
SECTION 4 DURABILITY AND COVER TO REINFORCEMENT
4.1 General
4) Corrosion protection of steel reinforcement depends on density, quality and thickness of
concrete cover (see 4.4) and cracking (see 7.3). The cover density and quality is achieved by
controlling the maximum water/cement ratio and minimum cement content (see EN 206-1) and
may be related to a minimum strength class of concrete.""
and you can look at the previous standard BS8110 Table 3.4 which gives nominal covers for various conditions of exposure against the grade of concrete.
You state that you are unaware of "the relationship of reinforcing cover to concrete strength", and state that it "is a new one on this Ove Arup trained ex Chartered Structural Engineer". I learnt this in technical college back in the 1970s.
I do not know if we were working to a new code that had introduced the relationship between concrete strength and required cover and you have not undertaken any concrete design since the you were initially trained. You could have been designing other things.
Alternatively you could have just forgotten, thats a sad fact of ageing. I certainly can not do some of the maths that I could do in University.
I think it is unlikely that you are deliberately giving bad advice. But you could have said something like with "20mm cover it will be 20 years before there is a problem in MikeJhn's experience" or the like "40mm is the standard but not needed for a shed".
I doubt you will explain yourself but I will take everything you say with a pinch of salt.
