The s was probably an f at that timeI figured this would not go over on this site but research sill , evidence of use in the 1200,s
Never an 'f' - but it might have been a long 's' or medial, which, to viewers today, could be mistaken for an 'f' though in reality is shouldn't since it didn't have a horizontal cross-line.The s was probably an f at that time
Did you put in a calligraphy drip on the under side of the window cill
Also does the cill over hang by at least 2.5 inches so the water can drop clear of the joint between window and wall?
The greatest hits of Silla Black blaring in the background as you toiled!Today while the rest of you were no doubt enjoying BBQ's and beers in the sun I was repairing a rotten window
Won't go into detail but had to repair this quickly and reuse the glass despite the fact that a new window would probably have made more sense.
As is always the case the problem was at the bottom and a bit of filler wasn't going to sort it.
New bottom sash was needed, made that on Friday just out of softwood.
Started with this
And an hour or two later you have this
Today I spliced some new bottoms on the jambs and fitted a new front to the cill then could fit the sash and glaze it.
Coat of paint and looks as good as new
Quick poll, cill or sill![]()
I've rebuilt the bottom thirds of box frames - it would have been way quicker to make a new window.Today while the rest of you were no doubt enjoying BBQ's and beers in the sun I was repairing a rotten window
Started with this
Can you post a link to that?I figured this would not go over on this site but research sill , evidence of use in the 1200,s
Is there need!! a cill is a cill unless it's a silly sillCan you post a link to that?
Ill tryCan you post a link to that?
try English Language and Usage cill or sill. I can't seem to post the link directly.Can you post a link to that?
Had never heard of a calligraphy drip before so was about to Google it then realised it was probably meant to say capillary drip,
