RogerS
orangeth....I quite like the bullnose idea but how do you finish it to match the doors...if the doors are high gloss finish ...in whatever colour from tbe very wide range available?
OK, maybe the sarcasm wasn't justified, although there was somethng about the way you made the original point that suggested that there was something that you could do that I couldn't.Scrit":2humfjoe said:I hardly think that sarcasm is called for when we are discussing installation rather than making of a kitchen. As you are no doubt well aware any experienced 2nd fix carpenter, joiner or even kitchen fitter will by the nature of the job be multi-skilled. i.e. be able to tackle small plastering, tiling, plumbing and flooring jobs and so forth. It is all part of the job of installing a kitchen, isn't it? Or do you bring in other trades to do an hours work when you install a kitchen rather than do it yourself?johnelliott":2humfjoe said:Scrit":2humfjoe said:I can plaster as well...... :lol: .
OOooh!, aren't you talented!!
Scrit":2humfjoe said:The principle point about using standard depth (570mm) carcasses, which you have unfortunately missed, is that if your carcass isn't 570mm deep then any built-under or built-in items like ovens, fridges, dishwashers, etc. probably won't fit. You omitted to point out that your method only works if you are not installing any appliances - a minor but important derail.
Even knocking just 5mm off the depth of the carcasses can make for problems with some of the dishwashers and ovens out there (fridges seem to be easier for some reason) and then you might additionally find problems getting items like hobs to fit correctly above ovens because of where gas pipes, etc need to go. I suppose that's why many makers/installers prefer to stay with "standard" sizes. It also means going wider is a more viable approach, but if a wall is bowed in or bellied out badly at worktop level I for one would find that visually very intrusive, so I'd fix the wall - even though that's not a woodworking task
Scrit
Yes, that you don't see the need to take into account standard worktop depths because you use custom width ones.. But that isn't the case for most kitchens. Let's face it John there's more than one way to skin a cat and each installation is different. The original question was, however, about upper cabinets, so maybe we should get back on topic?.......johnelliott":zm095k1g said:Well, if you think about it, you will remember that I said that the cabinets were spaced out 15mm. 15mm plus (in the case I described but one that is easily modified) 565mm is 580mm. Do you start to understand what I am driving at here?
Scrit":3glx7u8p said:Yes, that you don't see the need to take into account standard worktop depths because you use custom width ones
It's a pity that you can't get thicker stuff. 3mm is awfully thin and will tend to belly-out over time as well as being prone to popping out of its' grooves if given a good clout with a frying pan or the like. Have you thought about going the other way and using 19mm carcass material for the backs? After all you'll have those 8 x 4 sheets.....sean_in_limerick":3txf1i9y said:I could not source 6mm material for the backs anywhere - it's just not done here in the midwest area of Ireland - but i think I will be ok with 3mm material as the face frames will keep the cabinets square and i will add some bracing at the backs as well from 19mm material.
Well I still like solid wood tops, despite my comments elsewhere. But they do require a bit of worksean_in_limerick":3txf1i9y said:....I have also toyed with the idea of a wooden worktop - but I'm not sure I trust the stability of wood around moisture - possibly we will go with the laminated chipboard.
If you rebate the back that will hide any imperfecions - in addition the back can then be used to pull the carcass dead square and its' rigidity will be increased no end.sean_in_limerick":2x3wqaep said:Scrit-> I can get hold of 15mm stuff no problem - that actually might be the way to go now I think about it - it will save me having to groove the cabinet pieces for the 3mm back. I assume you would inset the back into the cabinet - could be a problem if the cabinet isn't perfectly square (gaps)?
