AndyBoyd
I have been for sometime wanting to run a computer connection to my workshop as the wifi won't reach it. Main reason is to listen to FiveLive and the footy commentary as they are much better quality than the weak MW signal that reaches to NL
Now between the workshop and the house I have a 35m telephone connection (4 core cable) and I was wondering is there anyway I can use this as a computer network cable? Network cables have 6 connections but I was wondering do you need to connect all 8 or like telephone cables can you get away with using less. You can buy Computer network outlet boxes with screw connectors for each wire. Before I try and use the telephone cable to pull through a network cable, I thought I'd ask this
I know this is not strictly a woodworking question (hence off topic) but would value greatly any advice
