Workshop power supply
DomP
27 Aug 2022
Herefordshire
I'm currently running all the cable in conduit up to trunking around the top of my workshop build for my electrician to connect up to the consumer unit etc, he is going to be installing 10mm² swa from my house consumer unit roughly 10m to my workshop. I've got a garage that is supplied by a particularly dodgy old cable and wondered if I should ask him to take a feed off my workshop CU to supply the garage, removing the old cable, can this be done or would it need it's own supply direct from the house?
I'm hoping so because the position of the CU in the house isn't ideal for running to the garage where as my workshop is more straightforward. I'll give him a call tomorrow if I can get him to answer, bloody elusive these sparkys
As you probably know, wire size is a function of the load each conductor can carry without reaching its heat limit less a safety factor. So, its all about the combination of the loads on the shop and the garage that you might be required at the same time, but your sparky should be able to size the CBs on both to make sure the cable is properly protected.
I recently did something similar and I ran my shop power supply cable 0.5m underground in a plastic conduit. The cable was certified to be buried without conduit but I also laid an ethernet cable alongside of it plus a small rope in case I ever wanted to pull another conductor out to the shop for a gate alarm or whatever. Now my shop has a good network connection as well as a 50 amp power supply. Unfortunately, the improved network connection takes away an excuse for failing to answer my wife's text messages, etc.
That's a good point with regards to ethernet cable, it's a bit far for reliable WiFi.
It's unlikely I'll be using much power in both places at once but as ever I'd rather future proof I think.
Depends on the calculations, it is a mater of loading and allowable volt drop but 10mm can handle around 7kW and has a volt drop of around 4.5mV per amp per metre so should be no issues and your elusive sparky will have to decide as he will be signing off the certificate for building control as it is notifiable under the regs.
Looks at the 550m run to the front gate, with wifi connection for the camera, gate opener and intercom...
'O'Reilly' in best Irish accent....
:ROFLMAO:
(I got a Unifi system here- each 'flying saucer' has about 150m range plus they 'mesh' seamlessly so extending the range is as simple as plugging in another 'dish' to a power source- each one has a solar panel, charge controller, small 12v lithium battery and a 12v buck converter to power the POE injector for each one, literally 'sitting up trees' in my bush lol)
:ROFLMAO:
Please send me a link to your "Unifi" system. I have set up a Deco mesh system but the flyin saucers don't have a range of 150m. At best mine are capable of 50m, depending of course, on the manner of obstructions between them. Also taking note of your solar panel chargers - are you mesh routers weather proof and thus can be placed outdoors?
You do not say what current draw or what duty cycle you require from the garage supply.
That makes it difficult for anyone to express an opinion and is a question your electrician should ask you before comitting either way.
If the power is to light a 40W equivalent LED bulb once a month when you are in the garage for ten minutes, that is very different to 4kW of grow lights 24h a day for a horticultural job on the side.
Standard Unifi U6LR-s- they are usable in 'sheltered outdoor locations' (in my case under the shelter of the solar panel above in a 'semi enclosed' housing ie baffles I built around the edge of the panel attached to a handy tree branch at the camp and the gate)
There's one at the shed. one at the 'old camp' about halfway, and another 'near' the gate itself- each mounted 10-12m above ground...
These beasts
from https://ubwh.com.au/Ubiquiti/UniFi-WiFi/U6-LR
I’ve recently had a supply installed to a new garden room with electric heaters and on to my workshop at the end of the garden. I made a list of the electrical kit I had and figured out the worst case scenario in terms of loading. The sparky was then able to do his calculations to determine supply requirements.
I would have thought daisy chaining to your garage shouldn’t be an issue unless you are going to be running some high wattage kit in there.
I'll definitely feel a lot happier having a new supply to the garage, I'm tempted to get him to replace my house CU at the same time, it's plastic casing has yellowed horribly
I also ended up with a new CU. The existing one had been mounted sideways and had a very temperamental main switch and the shower wasn’t even on an RCD.
Now have a new unit with RCBOs on all circuits and peace of mind.
Well worth doing whilst you have a sparky available.
These beasts
I'm a bit ignorant when it comes to technology, are these a better solution to get wifi to my workshop and around my garden?
Unifi is longer range (more aimed at 'commercial' users rather than home users, but they are great for long distance stuff- like I said, with one at the shed, one at the old campsite and another near the gate (they 'mesh' and act as 'repeaters' to each other) I can get streaming video from the gates security cameras and the video intercom system down a 550m long driveway- on a heavily tree'd bush block... lol, can even open the gate by remote now from the shed without having to go all the way down there...
This was taken by drone from the road out the front when I first bought my place- the arrow is where the shed (which has a starlink on it) is...
Drive a half kilometre down the drive to get to the shed...
That's 550m from sitting at the gate, driving down the drive and getting to the shed...
Fairly pricey new, but I bought 3 secondhand off ebay for $100Au each...
Between those three access points, I get coverage the full width of my property (270m side to side) and about 2/3's of the 'front to back' (exactly one kilometre from the front fence to the back)- the coverage right at the back drops off about 200/300m from the back fence.... (the sheds basically right in the middle of the block in every direction...)
If you want to see a real life setup in a rural area, Tiny Shiny Home has a UTube video about their setup in their property, covering 7 acres (about 20 minutes long)
From their dashboard (I'm not at home, but I can do the same with mine lol- has a lot of options)
As folks have said already, it depends on what you want to be doing in the garage. You do mention though wanting to future proof what you're doing. Raises an obvious question, is there a possibility that you might want an EV charger in there? If so discuss it with the sparky, a reasonably high power EV charger can easily draw 32 or 40A.
As I understand it your plan is a 10mm SWA cable from a domestic CU to the workshop, is that right? That's a pretty hefty cable out of a domestic CU. Another possibility might be to take a second supply out of the main mains supply cabinet, downstream of the meter of course, to a second smaller CU in the workshop or garage whichever is more convenient. Also do you have enough spare ways in the domestic CU to run things from there?
Just a few thoughts, though I expect you've already had them.
