woodbrains":1k9wv0fk said:
custard":1k9wv0fk said:
But what about when the finish itself depends on sanding?
If the finish needs any sanding then you can only really apply that finish over a previously sanded surface, otherwise when you sand the finish you'll cut through on the microscopic ridges that planing or scraping always leave.
I think it depends on the finish and how the plane is prepared. If the final smoothing plane strokes are made with a slightly cambered blade (and I mean slight) there should be no ridges caused by the corners of the plane, just lots of very slight hollows which overlap.
Mike, but where one hollow meets another there'll be a ridge. Apply sanding sealer or a shellac finish to this and then, when you sand, which you'll have to, you'll cut through that ridge and expose bare wood.
As a previous poster put it, there's a lot of Krenovian idealism out there but in the real world it's pretty hard to avoid sanding at some stage.
One great example is cherry, often touted as the perfect timber for an oiled finish on a hand planed surface. I once made an eight seater dining table like this. Within a few years it has started to look blotchy. A more experienced and wiser woodworker told me it was inevitable, cherry is notoriously patchy in terms of surface absorbancy, so it absolutely needs a coat of shellac before oiling, and if that's true then it absolutely needs sanding too.
